Fender Blues deluxe distorted sound
  • Fender Blues deluxe distorted sound
    Hi all.
    Im losing my hair on this one
    Was told it had distorted . I bugged a new set of tubes in for test, still distorted. and low ( ish on output, Tried another speaker
    when using the signal gen and scope i noticed at V3 Pin 1 - 6 the signal was all over the place
ID:	870165 up and til about no 3 on vol clean channel it would be good after 3 it would start to get like this
    BluesDeluxe_Reissue_2004_schematic_Rev-A.pdf
    Pin 6 V2 signal good i think Click image for larger version
    V1 pin 1 258v
    V1 pin 3 2.0v
    V1 Pin 6 245v
    V1 pin 8 2.0v
    V2 pin 1 245v
    V2 pin3 1.95v
    V3 pin 1 256v
    V3 pin 3 36v
    V3 Pin 6 256v
    V3 Pin 8 24v
    I think the fault is somewhere between V1 output and V2
    Ive tried other tubes and still the same
    can anyone help.... Be nice as i do this for the fun really
    Bassman 1965
    On all the amps of that series, the Blues and Hot Rods, I automatically check the solder, and redo it, on the power tube sockets, and check the 9-pin ones. Also I check the phase inverter plates, open plate resistrs happen too often. And I verify the speakers plugged into the main jack, not the extension jack.
    As to any distortion, use a scope or signal tracer to follow a signal stage by stage. Sine wave in, is signal still clean at V1-1, and at V1-6? Does it matter which channel is selected? Clean at V2-1? You have a power amp in jack, so plug signal into that, does that come out the speaker OK? Note that none of the solid state stuff is involved unless you use the FX loop, except for the mute transistor. JFET Q1 is always on my suspect list, too many of those in various brands of amps come up leaky. Nearby pair of zeners clamp signal at 16v, I rarely see those fail, but won't hurt to check.
      Thanks enzo
      Im running at present without output tubes. with tubes in and speaker attached or test speaker sound is distorted.
      Checked all the parts you say, and re-soldered the tube bases. two zeners are fine as are all the other diodes.
      Plate resistors are ok. i removed J1 and one leg snapped off while soldering it back so i fitted J112 which seems to be the same thing
      Its the same on both channels worse on drive channel
      Power amp in jack signal injected all good, double checked with audio cd and all good
      Signal at V1 pin 1. good and at Pin 6 its good >>Click image for larger version
ID:	840317 on X10 on clean with vol on max
      V2 Pin 1 Click image for larger version
ID:	840318 clean channel vol about half way
        Not sure what kind of signal level you are applying at the input jack.
        The schematic shows test points for both AC and DC levels. The DC are in boxes, the AC in circles.
        In the notes at the bottom of the schematic, it lists the input level to use, and where to set the controls.
        Check the AC levels at TP2, 5, & 8 under the listed conditions.
        You have verified that the power amp section is ok, so you only need to look at areas before the preamp out jack.
