How much tweed tolex for a 5e3 style cab
  • How much tweed tolex for a 5e3 style cab
    So i'm ordering a tweed tolex from Fender Vintage Tweed, 90 x 150 cm - Tube-Town GmbH
    I would like to ask how much do i need to order to cover the whole cab?
    *Sides you need 19 x 15" (x2). Btm you need 19 x 14". Top 19 x 13". P1 10 x 21". P2 6 x 21".
    * need to be opposite diagonal weave to the rest. So:
    IE: lying tweed with edge seam (not coated/ discarded) across top, L-R (&/ or btm L-R).. you need the rectangles of T/B P1/ P2 to be longways across L-R.
    Then you need the *Sides shorter side across L-R, and the longer length of 19" Up-Down.
    Sketch this out on a sheet (asking specifically whicjh way the diagonal in the "yd" is oriented 1s1 fromTTown (i cant remember). Then you can work out how much you need.
