UREI Model 1178 studio compressor channel issue
  • UREI Model 1178 studio compressor channel issue
    Hi to you all
    Happy new yr
    I have an old 1970's/80s studio compressor
    The guy told me that one channel was lacking in freq responce
    On checking one channel was lower output and lost its bass and and compared to the other channel
    I decided to change all the caps and for good measure the op amps . The caps looked old and tired and customer really likes this.
    UREI-1178 manual.pdf
    After changing caps and op amps Ic 1/2/3 and Ic 7/8 Still the same
    Psu is ok and correct
    I have a scope and an old signal gen, Tried a cd input and the signal gen
    with my limited knowledge of electronics im not sure where to go now.
    can anyone shed some light
    Bassman
    You have a working channel, no?
    Compare the two to find where in the circuit the signal is failing.
    Do any controls affect the problem?
    Does selecting Stereo or Mono mode have any affect on the problem.
      Hi Jazz bass
      None of the controls make a difference nor does the mono/stereo s/w
      Channel A is good
      I will have another look again later today
      Many thanks
      Bassman
