JBL EON 515-XT on bench, fails to power up--relay shuts off power after 0.5 seconds of operation, and thermistor is observed to get very hot during this short period, then unit draws only 10 watts thereafter. Found several references to this issue online, which led to the schematic and service bulletin, and this helped me identify two shorted MOSFETs, Q370 and Q371. I will replace these.
I'm hoping someone could help me spec parts at newark.com. I don't know whether to choose positive or negative Continuous Drain Current (Id) for the N and P MOSFETs.
![Click image for larger version
Example, here's a likely N channel I found: IRFZ30PBF - VISHAY SILICONIX - MOSFET Transistor, N Channel, 30 A, 50 V, 50 mohm, 10 V, 4 V | Newark element14
