Bias points
  • Bias points
    I want to add some external bias test points to my Marshall ....what is the correct technical term for these red and black "sockets" so i can order some ?
    maybe Mouser has some
    something like this i guess
    2pc 4mm Binding Post Banana Jack Socket Panel Mount for Multimeter Test Probe | eBay
      They are call "Tip Jacks"
      https://www.tubesandmore.com/products/S-H260
        perfect ! thanks
          Consider just fitting a stereo jack socket, 1/4" or even 1/8".
            If you wish to go down the banana socket route, you can get insulated chassis-mount versions in 2mm - good for meter probes.
              That would be just great when someone hooks up something they shouldn't
              nosaj
                I was assuming that the test points would be connected to the power tube cathodes and 0V; if so I can't envisage anything too bad happening.
                But I guess the test points may be to the plates and OT CT!
                  Yea it's just a headphone jack, go ahead plug in
                    If the test points are to 1 ohm cathode-to-0V resistors, then the sound wouldn't be much use, but I can't see that harm / damage would be likely?
                    I suppose that a user may think that if it was a headphone output, then a dummy load had been switched in, and so fail to load the amp output.
                    But various sockets live on the back panel of amps; it's the duty of the designer to label them, and the user to read and hopefully understand them.
                    For other types of test point, eg plate, it wouldn't be a good idea to put exposed high voltage sockets on the back panel, eg a guitar string may find its way in there.
                      I guess I should have put more thought in my typing.. I was thinking when you mention plate and Ot coupled with a pair of headphones for some electroshock therapy. Just evil thoughts
                      nosaj
                        A plate connection may be handy for electrostatic headphones!
                          Even when they are clearly labeled, people plug their connections in wrong. It h=may only have a small voltage on it, but if someone plugs their speaker in there insyead of the output jacks, PFFFFT, OT is history.
                            I had a Sessionette 75 for repair where the owner had connected the extension speaker socket to the main speaker output of a Silverface Twin Reverb, and the inputs of both amps to a splitter box. This was done to see if he could get any more volume/better tone from the Sessionette. The Twin was fine, the Sessionette certainly wasn't.
                              Never give the customer a chance to do it wrong, because he always will. Tip jacks pretty much will not take anything other than probe tips, unless you unbend a paper clip and stuff it in there. Using a common audio connector is just an invitation for some other thing to be connected there.
                              if you have been in the service biz long, I am sure you have encountered things that run on wall warts, and someone plugged the wrong one in. "Aren't they all the same?"
                              Even manufacturers do not always get this. A long time ago, we sold little MIDI thru boxes. Just a small thing with a bunch of MIDI ports. it ran on a DC wall wart. Someone plugged a reverse polarity wart into it, and blew it out. I had an appropriate wart, but I called the company to ask what is likely to blow up on reverse supply voltage in them. The guy was adamant we only use their proper wall wart. I told him I understood that, but customers can and do plug the wrong ones in. I was amazed they had no idea this might happen. I eventually figured it all out on my own, and made the customer happy. Sold a new wall wart in the process.
