Results 1 to 22 of 22
Thread: Cheap Practical Strap Locks
    Senior Member elipsey's Avatar
    May 2010
    Upstate
    268
    10
    The straps fall off my guitar while I'm playing now and then, but so far I have always caught it, and have never broken one. I know that if I don't use strap locks I will drop a guitar and break it when the audience is finally large enough to be truly humiliating, and then I will end up in one of those youtube guitar fail videos. Still, I have never been satisfied with strap locks. They are expensive, mutually incompatible, gadgety, plastic-ey, feel weird like my guitar is mounted on thrust bearings, or some combination of these undesirable traits that I find off-putting.
    While I was browsing at the hardware store today, my mind turned once again toward alternatives. I have tried snap rings, hairpin cotter pins, and various other things, but what finally worked for me was: 3/8" fender washers. If you unscrew the strap pin, they slide over the narrow end, and then you can screw the pin back on with the strap underneath. 3/8” fit the Gibson strap pins, 7/16” for the Fenders. They cost 12 and 17 cents, respectively. When they didn't quite fit over the strap pin on one of my guitars, I almost had to spend an extra 12 cents for a bigger one, but then I drilled a bigger hole instead.
    Pros:
    Strap will not come off without a screwdriver or breaking something.
    Costs 12 cents.
    Cons:
    Looks like it cost 12 cents.
    I'm sure I'm not the first person to think of this, but if it saves just one guitar it's worth boring the rest of you. Cheers!
    May 2010
    Sioux Falls, SD
    6,542
    Received: 1,377/1
    Given: 1,041/1
    16
    In a pinch, you can do the same thing with guitar picks and a pocket knife.
    Nov 2006
    Sacramento, CA
    503
    14
    Maybe try painting them the same color as the ends of your strap, then they will look like they cost 13 cents.
    May 2010
    Sioux Falls, SD
    6,542
    Received: 1,377/1
    Given: 1,041/1
    16
    Is it even legal to use a "fender" washer on a Gibson?
    Supporting Member John_H's Avatar
    Jul 2006
    Las Vegas Nevada
    1,131
    Received: 264/1
    Given: 255/0
    15
    The rubber washers from Grolsh bottles work pretty good.
    evh did it like this
    May 2010
    Sioux Falls, SD
    6,542
    Received: 1,377/1
    Given: 1,041/1
    16
    Quote Originally Posted by John_H View Post
    The rubber washers from Grolsh bottles work pretty good......
    Plus it gives you an excuse to have a fine lager.
    Jul 2014
    Oregon
    303
    6
    I've used those flat hex head 1/4"-20 furniture bolts (you know, the ones that hold IKEA together) for the strap pins on the guitars I've built. You really have to torque your strap slot over them, and I even had to widen the strap slot on a couple to get em on. Not locked, but that 1/4" post and flat head don't let go easily, and they come in black.
    Feb 2010
    12,171
    Received: 1,922/24
    Given: 4,841/11
    24
    I just recently came across the Fender "strap blocks", and they worked very well. They are a stiff rubber, (probably similar to the Grolsch washers). Each pack has a black pair and a red pair for around $3 per pack.
    Fender Strap Blocks | Fender
    Dec 2008
    Wernersville, PA
    13,024
    Received: 587/3
    Given: 306/0
    28
    Bread bag clip.
    Cheshire, UK
    2,288
    Received: 587/4
    Given: 306/0
    16
    I use these - straplok
    Supporting Member
    Dec 2009
    UK
    3,666
    Received: 383/0
    Given: 59/0
    14
    I took a chance on some Deal Extreme Schaller-type locks and they're pretty good. Just lucky, I guess. A tip when buying from DX - make sure you don't buy anything that you'd be upset about if you took it out of the package and threw it straight in the bin.
    Guitar Zinc Alloy Strap Locks - Silver (2 PCS) - Worldwide Free Shipping - DX
  12. #12
    Oct 2015
    NEPA
    843
    Received: 200/1
    Given: 140/0
    5
    Spend the $12 and buy shallers.
  13. #13
    Old Timer
    Chill-Ville, VA
    3,305
    Received: 763/6
    Given: 1,524/10
    18
    Or Dunlops... I learned that the Dunlops allow another player to use a non-lock equipped strap to use your instrument. Schallers, if not used with the Schaller locks, the strap easily slides off the button.
    Justin
  14. #14
    Oct 2011
    308
    Received: 22/0
    Given: 41/0
    9
    Quote Originally Posted by Justin Thomas View Post
    another player .... use your instrument
    what does that even mean!?
  15. #15
    Nov 2006
    Sacramento, CA
    503
    14
    Most Levy's traps have very sturdy leather ends. Put them on once and they're not coming off accidentally, especially with the oversize strap buttons that are common.
  16. #16
    Old Timer
    Chill-Ville, VA
    3,305
    Received: 763/6
    Given: 1,524/10
    18
    Okay. I use a fixed-adjustment leather strap on my Tele. If someone else wants to play my guitar with their non-Schaller equipped strap, because my one doesn't fit them (which happens often because I keep mine really high), the strap easily slides off the buttons. That doesn't happen with Dunlops, because the buttons are shaped more like conventional strap buttons.
    Justin
  17. #17
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,395
    Received: 271/2
    Given: 93/2
    15
    since each of my guitars has a single strap I just permanently affix them
    of course this negates the "today's a rainy Monday so I feel like using my faux leopard skin strap..." type caprice but c'est la vie...
  18. #18
    Supporting Member
    Dec 2009
    UK
    3,666
    Received: 383/0
    Given: 59/0
    14
    Quote Originally Posted by mozz View Post
    I already has some Schallers. They're $17 equivalent in the UK - how come something made in Europe is cheaper in the US than the UK? I was interested to see what the DX ones were like for the price. I've also got Dunlops, which I prefer.
  19. #19
    May 2010
    Upstate
    268
    10
    Quote Originally Posted by Jazz P Bass View Post
    Bread bag clip.
    I tried this, briefly, and was really quite amazed at how well it worked. I can't speak to the long term efficacy of this solution, but those little clips seem really tough, and they're free so it's even cheaper than my washers.
    You win the thread!
  20. #20
    Senior Member ThermionicScott's Avatar
    Dec 2009
    SW CR IA US NA PE
    608
    11
    The cheapest and simplest solution, of course, is to put on a brand-new strap and learn how to put on and take off your guitar without ever undoing the strap. By doing that, I can sling the guitar over my back with no fear of the strap letting go. But what fun is that?
  21. #21
    May 2010
    Upstate
    268
    10
    Quote Originally Posted by ThermionicScott View Post
    This is a good point. I generally consider the strap part of the guitar and don't remove it, except to move it to a different guitar. But I kind of buy them as souveniers when I travel, like with the names of places or music stores on them, so I don't always want to get rid of them even if the leather is streched out; hence the strap locks.
  22. #22
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    6,555
    Received: 1,563/21
    Given: 1,303/0
    14
    Quote Originally Posted by elipsey View Post
    Similar here. In fact I'm about to replace an old shredded fabric strap with another NOS one, both EarthIII's and how long have they been out of business? Good outfit, I miss 'em.
    I've long used bass string-tree buttons as strap buttons, or put a big washer between strap & button top, even have a few funky old cam-holed plastic wafers (what the dickens were they called?)
    I suppose if you have a hat or big hair, a wig (!) or elaborate clothing/costume onstage you have to snap the strap off the guitar. Otherwise I vote to stick it on & leave it on for good.
  1. Useful tool - strap wrench
    By Enzo in forum Music Electronics
    Last Post: 08-12-2011, 06:57 PM
  2. Replies: 6
    Last Post: 04-11-2011, 06:18 PM
  3. Does this seem at all practical for making pickup covers?
    By Chris Turner in forum Pickup Makers
    Last Post: 12-06-2010, 04:39 AM
  4. Vibration and resonance isolation - practical?
    By Ground Pounder in forum Guitar Tech
    Last Post: 05-03-2009, 01:04 AM
