Greetings. In trying to find out why I cant find a good sound. I had a theory that my speakers have inferior wiring. Does anybody know the speaker wiring method used on a fender twin. Is it wired in series or parallel. I noticed my telecaster sound best when its in the combined parallel mode. Is this why my Bugera 2x12 BC30 combo amp sounds muffled, its wired in series and not in parallel. Im changing my speakers next month to 4ohms and less watts in order to try to clean up its sound. Any help is appreciated. Gods blessings. Paul in wa state. Do they comprise sound by wiring in series only to order that the speakers dont blow as easy, if so, thats bogus.
A Theory about speaker wiring.
No, wiring has no influence.
Series or parallel pulls exact same power and subjects them to exact same stress if connected to the proper transformer tap, 16 or 4 ohms in this case.
Just checked: https://www.youtube.com/watch?v=lGAHG4OujFY
IF you find that amp muddy, you have a *gross* guitar problem, sorry.
As of:I noticed my telecaster sound best when its in the combined parallel mode.
a) pickups are under different vibrating string points, and capture very different harmonic content; combined sound is richer than any of them obn their own.
b) there is no impedance matching involved by any means, you always use same cable connected to same amp input, and cable capacitance is a treble killer, so parallel pickups have lower impedance and drive that load better ... none of that happens with speakers which are the exact same, receive exact same signal, and are impedance matched, so what happens with the guitar does not apply to amp/speakers.
With due respect, IF a Tele (of all guitars) and a Vox based amp sound muddy to you, maybe you should have your hearing checked.
Not an insult but maybe a Medical condition.
I have regular ear infections and lose all highs for a couple days each time.Last edited by J M Fahey; 01-30-2016, 05:59 PM.Juan Manuel Fahey
Originally posted by shootingstarno View PostIm changing my speakers next month to 4ohms and less watts in order to try to clean up its sound.
Also, also... If I interpret your post correctly, you would like for your Bugera BC30 to sound more like a Fender Twin. There are a lot of reasons why that can't happen. Too many to list and noting the most important differences would probably be upsetting. But in a nut shell, a Fender Twin is a lot more amp. The differences go far beyond just the speakers."Take two placebos, works twice as well." Enzo
R.G. One post said that my amp doesnt sound like a fender twin and that there are many reasons why, not just speakers and or ohms. If I take it to a tech. Are you saying he can add the parts to it, mod it to sound like a twin. Or should I just save my money for a Fender Twin. I know that, mine uses el84's and a twin uses 6L6s. Regardless. Thanks to everyone for posting response. Paul wa state.
A Fender Twin is going to have higher quality transformers, speakers, cabinet construction and likely tubes. It also has twice the power. Which makes a big difference in clean volume. The power tubes, 6l6 rather than your el84's, typically exhibit less intermodulation distortion. All this adds up to a large total difference.
If you are in any way infatuated with a Fender Twin then you won't be truly happy until you acquire one. In that case you should start saving for one.
If you think you could be happy with the Bugera I will suggest that the speakers will be the single biggest difference you can make. Not a change in ohms or how they're wired, but better quality and efficiency. Your net cost to do this would probably be between US $150 and $300. Unfortunately this is a very difficult and expensive thing to undertake. Which high end speakers you like best with that amp is something only you can decide. There are hundreds of options. Even reading reviews and asking for suggestions you're very unlikely to find your favorite on the first purchase. In fact you may never find speakers that make you happy. And just putting speakers into the amp to test reduces their resale value. But let's assume you get lucky and end up out only $200 for speakers.
The amp is worth maybe $300 on the used market. So that's the same as $500 ($200 you didn't spend and $300 you could get by selling). A Fender reissue or silverface Twin Reverb will put you back about $900. So that would be $400 more, but with possible maintenance needs like tubes or filter capacitors that might cost you $100 if you did the work yourself. The choices are yours. You're essentially $500 from a Twin or $200 from a question mark."Take two placebos, works twice as well." Enzo
Seems the perennial advice still rings true... if you <REALLY> want a Twin Reverb sound, just buy the Twin Reverb. I think $900 would bag you one in pretty decent shape. There is NO amount of modding, speakers or otherwise, that will make an EL84-equipped Bugera sound like a Twin. Unless you scrap EVERYTHING except the cabinet, chassis, and maybe speakers. Which, to put a Twin Reverb in that Bugera chassis, <IF> it will hold the Twin iron, will be way more than the likely cost of a real Twin. Sell what you must, and save the rest. But just get the Twin.
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Originally posted by Justin Thomas View PostSeems the perennial advice still rings true... if you <REALLY> want a Twin Reverb sound, just buy the Twin Reverb. I think $900 would bag you one in pretty decent shape.This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostTo lift it you may need an elastic back brace, not included. OOF!"Take two placebos, works twice as well." Enzo
Originally posted by Enzo View PostMy god, I have two of them.
My doctor told me not to lift anything heavy.
I even have to sit down to pee now...."Take two placebos, works twice as well." Enzo
Twins are Lear Jet loud, ice pick trebly, and hernia heavy. For clubs you might want to check out a Deluxe Reverb which many people refer to as half a Twin if you don't need the massive clean overhead. I THINK your Bugera is based on an Vox AC 30. If the speakers are like what are in my Bugera V22 I don't think a speaker change will get you much. It's all subjective, but the stock speaker is pretty good IMHO.
Originally posted by olddawg View PostTwins are - - - ice pick trebly - - -This isn't the future I signed up for.
