Power amp stability
  • Power amp stability
    In the picture is an audio power amp from about 1978 by AB Systems, Inc.
    I have replaced all the output devices with modern ones (some of the old ones had failed, but nothing else) and I get a little oscillation near clipping on the positive peaks of a signal. This occurs with or without a dummy load connected.
    I looked at the diagram and realised that it has many capacitors that I wasn't used to seeing in audio amps, arrowed in red.
    Any suggestions as to what they all do and why they are there, or is it just a bit of a mess?
    I can see the 47pF is the so-called Miller capacitance, but the others I have not seen before.
    The 0.05 uF caps around the V-I protection transistors are in the wrong place, but removing them didn't help.
    I can't see D17 and D18 being much help, either.
    Any thoughts?
    What condition are the main power supply caps in? 37 years old? Hmmm..... Still workin' more or less, might try bypassing them with film caps, say 0.1 to 10 uF to make sure main filters are also filtering very high frequencies.
    Never did have much luck with AB even when they were "newer", hope yours is better.
      I have also posted this here:
      stability in audio amplifiers - what were they thinking? - Page 1
      and there are several replies and a little more information from me.
