Results 1 to 9 of 9
Thread: Boosting filament Ampere rating
    May 2015
    106
    6
    Howdy folks, i scored a sweet old home made tube bass amp from the late 70's (guessing) 4x6l6gc's a 5751 input and a 12au7 P.I.
    The Output transformer is a hammond 1650T Massive 20lb iron that is rated for 120W rms. The Pt is my guess a 278cx 800v CT @ 530ma (this Pt is 6" wide from bell to bell). 6.3V @ 6A This is my issue. I want to reuse the transformers for a bigger tube amp.
    4xKt88 or 4xEL34 . I need 7A of filament current (4xel34's and 2x12ax7's is 6.6A...better but still makes me alittle nervous). I know hammonds are conservatively rated but adding an addition 1A seems like a real gamble. I have a vintage 60's hammond filament transformer 266L6 - 6.3v@2A sitting on the shelf. Can i wire this transformer parallel with the PT filaments to boost the current rating or will this cause balancing issues?
    im tempted to just wire it up with el34's and see where we sit. my goal was to use it in a hillbish Matamp GT120 clone chassis for 4xel34's
    Senior Member ThermionicScott's Avatar
    Dec 2009
    SW CR IA US NA PE
    608
    11
    You wouldn't want to wire the filament transformer in parallel with the larger PT's filament winding. Just use the extra filament transformer to power the preamp filaments by themselves. Easy-peasy.
    May 2015
    106
    6
    Ya i didnt think running them in parallel would work well i just wanted to double check. But If i use 4xKT88's it will put the current on the PT at 6.4A thats prob ok for the transformer?
    Dec 2009
    SW CR IA US NA PE
    608
    11
    Let's see... my first thought was to wire one of the output tube sockets to the filament transformer, but then you'd be over its limit.
    I suppose you could try the old PT with 4 KT88s on it and measure how warm the PT gets and whether the filament voltage sags under 5.7V. I think the best practice would be to get your hands on a 2.5A filament transformer and wire one of the output tubes to it so that you are well in the clear for all uses.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    16,482
    Received: 3,097/5
    Given: 3,732/0
    32
    That filament winding will be fine. Better than fine actually. Many transformers, Hammond included, rate the filament winding for voltage @ current. That means that it is designed to give the desired 6.3V at the specified current. Run at anything lower than 6A and your filaments will be OVER 6.3V. In other words, those aren't max ratings, they're operational characteristics. Since modern wall voltages run higher than when that PT was made you will probably be glad for any sag that might work to correct an otherwise higher filament voltage.
    This has been my experience with Hammonds. They probably wouldn't make an off the shelf PT for four big bottles and then limit it's use to one tube type. That would be inconsistent with their product line. But don't take my word for it. Do check with a long burn in to see that the PT doesn't get overly hot. And have a contingency plan for the auxiliary filament transformer when you plan the build. That way you won't need to retrofit it in there if it comes up.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    33,498
    Received: 2,543/7
    57
    I agree there is probably no real issue using it for the extra half an amp. 10% over spec is no big.
    However, I have to wonder how you came up with that spec. You don't mention a make and model PT, only the OT. And you GUESSED at the high voltage ratings. SO is the 6A rating on the heater voltage also a guess?
    Apr 2015
    Minneapolis, MN
    333
    Given: 1/0
    6
    Quote Originally Posted by ThisLifeILead View Post
    4xKt88 or 4xEL34 .
    Just a little side note here. If you are guessing that it had 4 6L6s and you want a "bigger" amp, I'm assuming more power. EL34s are rated for 25W whereas 6L6GCs are 30W tubes. You will get less power from the EL34s than 6L6s. So the extra heater current drawn by them is non-productive. The KT88s make sense.
    I'm in agreement with Enzo. I think it's best to determine the actual capacity of the filament winding instead of guessing. And in in addition to agree with Chuck, hook up the amp how you want it for a long enough time to get a heater voltage reading. If you're at 6.3v, you're fine. Even a little low by .1v or .2v is OK. Hammonds are over-built, so should take some small amount of extra current draw as Enzo stated.
    Turn it up so that everything is louder than everything else.
    Near Dallas Texas
    3,577
    Received: 266/0
    Given: 134/1
    19
    The PT in a Traynor YBA-3 is generally considered to be an OEM version of the Hammond 278CX. Early versions of the YBA-3 used a quad of 7027A plus three 12AX7. After about 1968 or 9 the YBA-3 came with a quad of EL34. I re-built a YBA-3 to use 6550s. The heater Voltage was on the low side, about 6.1VAC at the first power tube. I replaced the long feed wires from the pilot light to the first power tube with #16 teflon wire and that brought the Voltage up to 6.3VAC. The PT runs warm (not hot) and benefits from the fan cooling standard on that amp.
    If Hammond is listening they really need to up the heater current to 8A on the 278CX. With the high power available from the HV secondary, you need more heater power to light up the tubes.
    http://www.hammondmfg.com/pdf/EDB278CX.pdf
    May 2007
    pacific north west
    16,482
    Received: 3,097/5
    Given: 3,732/0
    32
    Quote Originally Posted by loudthud View Post
    Well... They could bump the rating. But they probably know that the transformer will survive even if it's hotter than you'd think is alright Of course you're right. I'm just making some fun. Hammonds are Tough (< capitol T).
  1. boosting highs/ adding presence control?
    By beedoola in forum Mods & Tweaks
    Last Post: 04-17-2013, 12:37 AM
  2. What rating fuse to use?
    By paggerman in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-23-2011, 01:37 AM
  3. Help with OLD to NEW Varistor Rating
    By flythair1 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-26-2011, 09:38 PM
  4. Fuse rating
    By 62strat in forum Music Electronics
    Last Post: 08-23-2008, 03:36 PM
  5. Boosting a Warwick Sonic II giving trouble
    By aceofspades_71 in forum Other Amps
    Last Post: 12-04-2006, 06:38 PM
