Results 1 to 18 of 18
Thread: 5 string p bass pickup
    May 2010
    Valkeala Finland
    177
    I've looked at 5 string p bass pickups and Nordstrand pickups caught my eye because they have normal sized covers, not one shorter and one longer cover which are harder to find. I suppose there is same size bobbin in both halves, the other is just made without one pair of magnets and instead it has either metal or plastic slugs. What do you think?
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    Marko,
    Actually they do have the 5th and 6th magnet under the cover but these aren't magnetized. It's a really easy way to achieve full hum cancelation.
    May 2010
    Valkeala Finland
    177
    I guess steel poles without magnets will work as well. I have to wait for the covers before drawing bobbin plates for CNC.
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    Alnico has a lower permeability than iron so it makes sense to stick with identical materials though it probably won't make a huge difference. I think I've read here that AlNiCo has a permeability similar to that of air so a plastic slug might be better than a steel one...
    May 2010
    Valkeala Finland
    177
    In that case I'll use plastic.
    Old Timer
    Feb 2010
    Just south of Bawlmer, Merlin
    2,381
    Received: 95/1
    Given: 67/1
    What type of magnets are you planning to use?
    Relative permeability of neodymium magnets is near 1.
    A cursory Google search on alnico shows a range of values of about 1.3 thru 6.7, depending on type, conditions, and who you ask.
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,301
    Received: 200/21
    Given: 202/9
    If you want it to have P-bass tones?
    Then it needs to have Alnico rods for the main poles.
    Don't you think?
    T
    “When you find yourself in a hole, quit digging.” WILL ROGERS
    Keep Rockin! B_T
    May 2010
    Valkeala Finland
    177
    Wound but not tested yet as the bass is on the drawing board. I made a split coil J pickup as
    well. 9500 rounds on P, 10000 rounds on J. I have to charge the magnets before testing.
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    Marko,
    You won't get very effective hum cancelation on the split J if the coil's turns*areas aren't the same, the shorter coil will need some additional turns to make up for the shorter coil length. With more turns it will need slightly weaker magnets to have the same output. You might try 9000 turns on the longer coil vs 12000 on the shorter one and then load the shorter one with A2 magnets while the longer one has A5s. You can also discharge the short coil's A5s by 30% or use a fatter or better yet a longer magnet (making a taller coil for the extra turns).
    May 2010
    Valkeala Finland
    177
    Sounds like this. I hear no problem humbucking the J so I guess this is how it's going to be. P, J and both with two a bit different settings.
    Maihinnousu - Lataa - MPU - 5pj16
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    It sounds quiet enough to me, maybe I'll try one after all. Did you have room to wind the J with 42awg? I'm wondering if the offset magnets helped with the bobbin space and with the magnetic cancellation at the join.
  12. #12
    May 2010
    Valkeala Finland
    177
    Quote Originally Posted by David King View Post
    I wound the J with 43awg. There was less room at the sides than at the join. It was tight to get 10000 rounds with 17mm string spacing bobbins.
  13. #13
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    I bet it was! Now try it on 19mm in a short j shell the way Carey does.
  14. #14
    Jul 2014
    Oregon
    303
    Quote Originally Posted by Marko Ursin View Post
    Just to clarify: the P is actually using 3+3 bobbins, but one is only mag loaded for 2 strings, and 4750 turns on each; the J is using 3+2 bobbins, with some combo of 10,000 turns between the two?
  15. #15
    Jun 2010
    Mid-South USA
    10,301
    Received: 200/21
    Given: 202/9
    The 9500, & 10,000 turns, should be per bobbin.
    T
    Keep Rockin! B_T
  16. #16
    May 2010
    Valkeala Finland
    177
    Quote Originally Posted by big_teee View Post
    T
    That's right.
  17. #17
    Pickup Maker David Schwab's Avatar
    Staten Island, NY
    10,946
    Received: 2/0
    Given: 3/0
    Quote Originally Posted by rjb View Post
    I wouldn't use neo rods though. Too much string pull. Alnico is bad enough.
  18. #18
    Old Timer
    Feb 2010
    2,381
    Received: 95/1
    Given: 67/1
    Quote Originally Posted by David Schwab View Post
    I guess I didn't clearly make my point.
    Please reference posts 4, 5, & 6
    Post 4:
    David King says the unmagnetized dummy slugs should have the same permeability as the magnetized poles- but he mis-remembers that AlNiCo has permeability close to air (i.e. relative permeability close to 1).
    Post 5:
    So Marko concludes that he should use plastic slugs.
    Post 6:
    I clumsily point out that neodymium has a relative permeability of 1, and AlNiCo has some higher permeability.
    I didn't follow through and state what I thought was the obvious conclusion:
    1) Since you are probably using AlNiCo magnetic poles, then use unmagnetized AlNiCo slugs.
    2) If, for some reason, you are using neodymium poles, then use plastic slugs.
    But yes, I would expect neo rods to be too strong for bass pickups.
    EDIT:
    This is all water under the bridge.
    Marko has already built his 5-string P & split-J set, and they sound great.
  1. 5 String Jazz Bass Pickup Issue
    By TheGrateOz in forum Pickup Makers
    Last Post: 02-27-2013, 04:58 PM
  2. Pickup kit for 5 string bass
    By cenizasblancas in forum Pickup Makers
    Last Post: 09-25-2011, 05:23 PM
  3. anyone know a good source for 5 string j bass pickup covers?
    By Bryan Jeppson in forum Pickup Makers
    Last Post: 05-03-2011, 02:57 PM
  4. Tutorial on Making A Bass Pickup for a Single String.
    By dustintmoney in forum Pickup Makers
    Last Post: 08-25-2010, 07:01 AM
  5. pickup for a 5-string upringht-bass
    By oahu in forum Pickup Makers
    Last Post: 07-11-2007, 05:30 AM
