The music shop took in an Ampeg a Micro CL bass stack on trade. Of course did not fully test it. It has an overall muddy raspy tone at all volume levels, and,just read similar complaints on various bass player forums...some said it was an acknowledged factory problem. It's not the cabinet. Did not check but some geezer said headphone out was clean. Doubt if I could get any info out of Ampeg. Anyone know about this or any suggestions? Thanks.
Ampeg Micro CL distortion
Yes sir. The cabinet sounds great with my micro VR head ( I play bass). And the Micro CL head sounds raspy with VR cab. Also headphone output is clean. As stated above, there is enough talk on various forums to suggest there is some type of design defect or premature failure.
I don't have a schematic or have not devised a plan to isolate the cause of the distortion.
Thanks.
Try both side by side going back and forth and also plugging same cabinet into one or the other, simply to make them work in a very similar way.
If you confirm that the CL head works significantly worse than the VR, * at all power levels, even bedroom and garage* , then no doubt it's a head problem.
You might make a simple YT video showing that, play a few bars with one, then with the other, go back and forth 4 or 5 times so our ears become accustomed and notice differences better.
Now if bedroom level works fine in both and CL cr*ps at higher levels while VR stays clean, maybe that's nthe nature of the beast, 100W vs. 200W .
Many say "but that's just a negligible 3 dB difference" .
Maybe so, but countless times 100W has been crushed by the drummer, and 200W , "only 3 dB more" does the opposite, so in that case you sould really have nothing to "repair".Juan Manuel Fahey
Originally posted by fredcapo View PostDid not check but some geezer said headphone out was clean.
Originally posted by fredcapo View PostDoubt if I could get any info out of Ampeg.
Originally posted by fredcapo View PostAnyone know about this or any suggestions?
Mark
Yes did the side by side swap instrument and cabinet comparisons, high and low gain. This particular CL sounds fizzy, leaves a fuzzy, raspy artifact as the note decays. Sounds a bit better in the -15 db input. Headphone output uniformly clean. Did not try aux out yet. I will call Loud for support...I was unnecessarily dismissive above...guess was thinking Stl music...
Originally posted by MarkusBass View PostBased on your very brief description there is chance that bias in the power amp is set incorrectly.
Another possibility is a shorted/leaky limiting transistor in the power amp. Also easy to see with the oscillator/resistor/scope rig.
One last: if there are rail fuses in the amp maybe one has gone open circuit.This isn't the future I signed up for.
There are many possibilites to the cause of the 'fizzy'.
Try to narrow it down to the power amp or preamp.
FX return will bypass the preamp.
Aux in will bypass the tone controls.
FX send will bypass the power amp.
Micro-CL_OM.pdf
Thanks for the manual w block diagram...I was not expecting that the headphone jack comes directly off the speaker leads... Padded headphone out sounds fine, but speakers sound raspy distorted... Is that diagram correct?
Will try things suggested when I get to the shop tomorrow. Thanks guys.
Originally posted by fredcapo View PostThanks for the manual w block diagram...I was not expecting that the headphone jack comes directly off the speaker leads... Padded headphone out sounds fine, but speakers sound raspy distorted... Is that diagram correct?
Mark
Markus - I have not opened up the unit yet. But thinking it would be possible for headphone jack to open the speaker leads, yet take a signal from another point in circuit...thanks
Got the expected response from Loud...
Unfortunately, schematics for our current products are ONLY available to our authorized service centers or distributors. There is no acknowledged defect with these amps that I am aware of.
All the best,
BBBenton...have you fixed your Micro CL? I wasnt ready to invest the time to break down mine to troubleshoot and put it on the shelf. Easier to just use my Micro VR. Seems to have been a problem enciuntered by several. Some folks said it was the speakers, but not in my case.
Here is the schematic for the amp... I would test all power supplies and then trace the signal all through the amp to see what I could find. Perhaps soldering imperfections can be found on R129. Got to start at the start again.Attached FilesWhen the going gets weird... The weird turn pro!
