Hi there!
I am new here, but have been playing guitar for many years, and have a bit of an odd problem with one of my pedals.
The Boss MT2 Metal Zone, has no clean tone!
This is a new development with the pedal.
If I plug it in, and play, there is absolutely no tone when the led is not lit.
When I stomp it, activating the distortion, the sound comes through as it should, with a nice chunky distortion, and all variables work, with regards to tone, bass, level and distortion etc.
As soon as I stomp it again, to deactivate the distortion effect, there is complete silence, other than the twang of an unplugged electric guitar.
Does anyone have any ideas as to what I can do to fix this?
I would understand if it was the oterh way around, and the clean tone worked, but the distortion effect was not working.... but this is odd!
Now, over and above this, my very first pedal, of which I am very fond, due to it's backward wiring **(Factory error!!), an Ibanez Sound Tank Powerlead pedal, the switch has become a little iffy ... and requires multiple attempts to keep the effect on.
Is there any particular switch I can use for the pedal?
Incidentally, the pedal came with the incorrect value resistor or something, because when I crank the tone to increase treble, the pedal increases the bass value exponentially, giving the most amazing chunky bottom ends!
A friend had the same pedal as me, but his was wired correctly, so when he cranked the tone, his treble value increased, as did all other Powerlead pedals I tried in stores..... so I am pretty keen to get this one fixed!
Thanks for the help!!
