Results 1 to 14 of 14
Thread: Hand vacuum for potting pickups?
    Member Emeritus Forever Steve A.'s Avatar
    4,506
    Received: 129/0
    Given: 77/0
    18
    I just noticed this in the latest catalog from American Science and Surplus. Is a vacuum of 2" HG sufficient for potting pickups in a crock pot rig?
    $22.85 with free shipping through April 3rd.
    VACUUM HOME PUMP
    NATURE ABHORS A VACUUM
    But science teachers can't work without them. Experiment with this good-quality manual vacuum pump made of durable polychloroethylene plastic. Works with a pistol-grip action and pulls up to 2" Hg. Includes a 17" length of clear vinyl, 1/4" ID tubing, and a release valve
    Steve Ahola
    Nov 2006
    Sacramento, CA
    503
    14
    2" of mercury is not much. I helped a friend make rubber molds, he had a vacuum chamber that would pull down to a near vacuum (nearly 30" of Hg) to get the bubbles out of the liquid rubber. It was essentially a pipe with a plate welded to one end, a lid, an air compressor set to draw air from the chamber, and a couple of valves. 2" is not a lot of vacuum, about 1 psi, compared to 14.7 psi. How many pickups do you want to do? What are you using for a vacuum chamber?
    Senior Member elipsey's Avatar
    May 2010
    Upstate
    268
    10
    Here's what I use:
    This is a 12V automotive tire pump inside a gasketed plastic food jar, with the outlet hose connected to a tire valve. So, basically, since I couldn't afford a vacuum pump for sucking, I got a tire pump for blowing, and turned the world inside out.
    A brass nipple is threaded into the top of the jar, which is connected to a vinyl hose, which is in turn connected to another brass nipple soldered into the top of a ball jar. The ball jar is filled with 70/30 beeswax/parafin. I melt this in hot water with a sealed lid on it, while monitoring the water with a thermometer. When the temperature is right, I unscrew the normal lid, put the pickups in, and thread the vacuum pump lid onto the jar. Then I connect a power drill battery to the jumper wires until the pump guage shows the desired vaccum. It will develope about 10psi of vacuum, which seems to be more then adequate for this purpose.
    4,506
    Received: 129/0
    Given: 77/0
    18
    As an HVAC service tech I've worked with refrigeration vacuum pumps that go down to 50 microns but don't know how that translates to inches...
    I like the rig that Pete at Vintage Vibe uses: a crockpot with a gasketed clear plastic lid that has a scrader valve to hook up his vacuum pump. He uses a variac to control the temperature.
    Steve A.
    Nov 2006
    Sacramento, CA
    503
    14
    I like how you out the pump inside the jar to get the suction. Can you see bubbles coming out of the pickups when you used it?
    May 2010
    Upstate
    268
    10
    Quote Originally Posted by Richard View Post
    Yep.
    May 2010
    Upstate
    268
    10
    Quote Originally Posted by Steve A. View Post
    Steve A.
    That sounds pretty pro. I used a ball jar partly because they are intended to stand up to vacuum. I wonder how much vacuum the average crock pot will tolerate before imploding? Apparently that one could take it...
    Nov 2006
    Sacramento, CA
    503
    14
    I had to look it up. 50 microns is probably about as pure of a vacuum as you could get outside of a lab. Inches Hg gets higher with more vacuum, measuring what is taken away, microns is what's left.
    CNC Trial by Fire kayakerca's Avatar
    Jul 2011
    Ottawa, CANADA
    773
    Received: 18/0
    Given: 37/0
    9
    Steve A.
    That sounds pretty much exactly like what I use, including the variac for temperature control. Works great. . .
    I have long since reinforced the lid (based on comments by Jason Lollar on his lid implosion experiences with less structurally sound lids).
    Take Care,
    Jim. . .
    VA3DEF
    ____________________________________________________
    In the immortal words of Dr. Johnny Fever, “When everyone is out to get you, paranoid is just good thinking.”
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,881/23
    Given: 1,463/35
    27
    Loved your vacuum potting ideas
    Will try something similar for vacuum impregnating my transformers, so far only drop them in the pot, hanging from wires, until they stop bubbling (~15 minutes) but obviously this is better.
    Thanks.
    Feb 2015
    151
    Received: 56/0
    Given: 6/0
    5
    yes- pump, crock pot, variac, offset vacuum line location in lid, 3/8 to 1/2 inch thick lexan running about 20- 22 inches of vacuum for a short period of time- 10 seconds to 1m30 or so depending on what you want to accomplish. Add to that pre heat your wound pickups so you can be sure your results are consistant. I domnt see much bubble action until the vacuum gets up close to 15 plus
  12. #12
    Jul 2011
    Ottawa, CANADA
    773
    Received: 18/0
    Given: 37/0
    9
    Quote Originally Posted by Lollar Jason View Post
    Forgot about the pre-heat part. I use a pair of shop lamps to warm them up to a point where they take the wax nicely and you have a bit of time after the potting to wipe the pickups down without the instant solidification of the wax when you remove them from the pot.
Name:	clamp lights.jpg
    Take Care,
    Jim. . .
    VA3DEF
  13. #13
    4,506
    Received: 129/0
    Given: 77/0
    18
    Quote Originally Posted by kayakerca View Post
    We have TAP Plastics stores where I live and they sell Lexan rounds in various diameters and thicknesses. Pete glued on a thick o-ring to make a tight seal with the crock pot.
    Steve A.
  14. #14
    Jul 2011
    Ottawa, CANADA
    773
    Received: 18/0
    Given: 37/0
    9
    Steve A.
    I really like the o-ring idea! A little less clumsy than my rubber gasket setup.
    Take Care,
    Jim. . .
    VA3DEF
  1. Vacuum Pump for potting pickups
    By SpareRibs in forum Tools and Coil Winding Gear
    Last Post: 12-01-2014, 01:27 PM
  2. Vacuum Pump for potting pickups
    By SpareRibs in forum Beginner/ Hobbyist
    Last Post: 11-25-2014, 02:49 AM
  3. The difference between a wax soak and vacuum potting.
    By rhgwynn in forum Pickup Makers
    Last Post: 03-28-2013, 04:25 AM
  4. Vacuum Potting in the "At Home" Shop
    By kayakerca in forum Tools and Coil Winding Gear
    Last Post: 12-15-2012, 12:10 AM
  5. How high a vacuum for wax potting ?
    By the great waldo in forum Pickup Makers
    Last Post: 08-29-2009, 10:09 AM
