Results 1 to 8 of 8
Thread: Need Help Diagnosing a Marshall Valvestate 8200
    New Member
    Mar 2016
    4
    0
    Hello,
    Nice little forum you guys got going here. This is my first post, but after perusing your site for a few days I think I am probably in good hands with my issue.
    I played this amp for 5-6 years with no problems, then just recently the boost channel stopped working. It also had a real scratchy master volume pot, so I purchased some contact cleaner and a new 12AX7 and went to work, hoping this would take care of it.
    I cleaned all the pots and all the jacks and installed the tube, but still no boost channel.
    Here is what I know;
    Old tube was a Telefunken ECC83 30170, new tube is a JJ T-12AX7-S, EEC83 S
    Volume pot issue is fixed
    Upon a good visual inspection of the viewable component side of the PCB's, everything appears good. No blown caps or burnt resistors. Nothing obviously fried.
    When pressing the boost channel switch, nothing happens and LED for boost channel does not come on, and none of the knobs work
    LED for footswitch (a Crate 2 pedal switch that worked before) does not come on for either distortion or chorus
    Chorus appears to work
    4x12 cab is good
    The f/x pedal I use in the loop doesn't seem to make any difference in the sound
    It also appears that someone may have hot-rodded this thing, there are two resistors wired onto the PCB near the input jack that don't look stock to me.
    I have some electrical knowledge and skill. I am real good with cars, and can wire my house. I have also done some PCB soldering, and diagnostics down to the component level but only for a year or so.
    I have never worked on an amp.
    I did pick up some Marshall schematics for an 8280 from another site that I think I found linked here, approximately 5 of them, but really dont know much about this type of circuitry.
    I do have a DVOM and soldering iron and all the necessary tools to repair it, except the know-how.
    I like this amp, so any help would be much appreciated.
    Thanks!
    Old Timer
    Jun 2007
    5,124
    Received: 102/0
    Given: 63/0
    19
    Welcome to the place
    Quote Originally Posted by Trfsrfr View Post
    Either post the schematic here or at least a link to it.
    The fact that the switching leds do not light up point to a possible problem with the low voltage power supply.
    The added resistors may be a factory mod. There were a few for this model.
    New Member
    Mar 2016
    4
    0
    This is what I have, and thank you for the reply;
    8280-60-02.pdf8280-63-02.pdf8280-62-02.pdf8280-61-02.pdf8280-64-02.pdf
    Old Timer
    Jun 2007
    5,124
    Received: 102/0
    Given: 63/0
    19
    Some of your pdfs aren't working due to a technical glitch, but if you look at drawing 8280-62-02 for the preamp, the switching circuit is at the lower left side of the drawing.
    Panel SW2 is the boost channel switch. It is powered by +12 volts, which comes in via CON 1. So make sure that connector CON1 is solidly pressed into the socket, etc. In fact just make certain that all of the connectors are solidly seated all through the amp.
    If you have a voltmeter and feel safe in working on the amp while it's plugged in, read the voltage at R14 to see if you have +12 volts dc there. R14 connects to the panel led so look for it where the led is mounted. The channel switch will ground the voltage there when the channel is set for the clean channel, so test the voltage with the switch in both positions.
    Stay away from all of the high voltage areas of the amp and be careful with test leads on the live pc board. Accidentally shorting things with the meter probe can make for a really bad day.
    New Member
    Mar 2016
    4
    0
    Okay, thanks again for that info.
    This is what I have;
    6.37v at one side of R14, and
    1.715v at the other side, and
    .083 and .077 volts when switch is pressed.
    I also have 11.87v at one side of R49.
    Edit: I noticed while checking voltages that the LED was coming on, so I plugged the guitar in and guess what?
    It appears to be working now.
    I will put it back together and play with it later and let you know what I find.
    Dec 2008
    Wernersville, PA
    13,074
    Received: 610/3
    Given: 314/0
    28
    For reference: VS 8280.zip
    New Member
    Mar 2016
    4
    0
    Excellent, thank you JPB!
    I'm not sure why my attachments didn't work.
    Update- Amp is working now. Not sure why. Maybe a cold solder joint?
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,753
    Received: 1,885/23
    Given: 1,463/35
    27
    Yes.
    You pushed unconnected parts together when pushing with your meter tip, but you can't trust that, it will come out with vibration, specially during a hot solo or something, so just redo all nearby soldering adding a tiny bit of solder, you don't want to create a blob which shorts something unwanted.
    Stay ay least 5 seconds on each solder or make sure it actually melts.
    Many, for fear of burning the PC stay too little so fresh solder added sticks on top of old (cold) cracked one, without actually repairing it.
  1. Valvestate 8200 volume fade
    By Disincarnated in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-20-2014, 05:20 AM
  2. Marshall valvestate 8200 bi chorus problem!
    By the crush in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-07-2013, 06:22 PM
  3. Marshall valvestate 8200 poping noise and low volume from left speaker outs
    By racefan56 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-05-2010, 05:31 AM
  4. what is the correct amp fuse for marshall valvestate 8200 bi chorus?
    By dtobian in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-15-2008, 12:59 AM
  5. marshall valvestate 8200
    By dtobian in forum Guitar Amps
    Last Post: 01-14-2008, 10:46 PM
Tags for this Thread
