Results 1 to 12 of 12
Thread: pignose 30/60
    Feb 2015
    trinidad WI
    33
    Received: 1/0
    pignose 30/60
    hi.
    Does anyone have a schematic of a pignose 7-3060 amp.
    i have one to repair but not sure if it has correct components looks like been repaired a few times before and some strange transistors, the output stage has 2n6031 and 2n3055 but they are not really a complimentary pair, should be either mj2955 with the 2n3055 or a 2n5631 with the 2n6031,
    thanks
    Dennis
    May 2010
    Sioux Falls, SD
    5,415
    Received: 406/1
    Given: 325/0
    You might try them directly.
    Contact Us ? Pignose Amps
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,413
    Received: 560/15
    Given: 456/13
    Used to have it many hard disk crashes ago; if I find it, i'll post.
    That said, 2 details:
    1) I seem to remember that output rail (transistor collector/case) is grounded, so "speaker out" is`the midpoint between filter caps.
    Not 100% certain, please check.
    2) even if not strictly complementary, both pairs you mentioned still meet and exceed what's needed there so a mix is`still functional.
    No need to address that unless one is blown.
    3) what is the actual problem you are trying to solve?
    Edit:
    this is its larger brother , the`150R, should be very similarv , kindly posted by Teemuk at DIY Audio:
    Feb 2015
    trinidad WI
    33
    Received: 1/0
    filter caps
    Edit:
    Thanks for the information the amp is working but does sound distorted and my main aim is to return it to original spec, the power supply is more basic than the 150R i don't know if the the 2200uf is the correct value for the filter cap as they were an old aluminum can electrolytic and a modern day capacitor.
    so if i can get the original schematic it would be very good
    thanks
    dennis
    Oct 2007
    10,413
    Received: 560/15
    Given: 456/13
    Feed it 100mV 440Hz, set all tone controls to 5, rise volume until the output until it just starts clipping and *a little* beyond, and show us waveform and voltages (+/- rails and RMS across load) .
    That will clearly show us whether you have a real problem or not.
    http://www.mediacollege.com/audio/to...6bit_30sec.mp3
    Play it through MP3 player, phone or computer , and set player to "loop/repeat" so after it ends (30 seconds) it starts again indefinitely.
    Feb 2015
    trinidad WI
    33
    Received: 1/0
    OK i will set that up i have a signal gen so the input is not a problem i will have to put in another 2200uf cap as one is no good after testing so it may be better with just that replaced, still want to bring it back to original i have emailed pignose but not had a reply as yet.
    i will be working on it over the weekend
    thanks
    dennis
    Feb 2015
    trinidad WI
    33
    Received: 1/0
    3060 crossover bias
    hi
    i got the schematic for the pignose 3060 and have replaced the parts that were not as original, it is working but the idle current is too high about 450ma so it gets very hot. on the schematic it says at note 3) crossover bias should be set for just visible at 95-100 vac (use variac) but i have no idea how or what to adjust. help is required.Click image for larger version.
    Attached Files Attached Files
    Dec 2009
    Devon, UK
    3,007
    Received: 281/1
    Given: 265/1
    Quote Originally Posted by mellowamoya View Post
    hi
    Double check the component values. These are usually set to a very low bias current and don't need adjusting. They rely on feedback to fix any crossover issues. It seems odd to me the the current is so high. Could one of the D4/D5 1N4148 diodes be open? How about the 33 ohm resistors R21/22? If they are low it will increase the idle current.
    Failing that you could try increasing R23 and R24 - keep them the same value - I wouldn't go any higher than about 10K as you might starve the output stage of needed drive current.
    Feb 2015
    trinidad WI
    33
    Received: 1/0
    thanks nickb
    on the schematic and on the board r21 is 33 ohm and r22 is 47 ohm? i see on similar circuits they have a pot between the bases of q1 and q2 to set bias.
    i know this is a variation of an old amp circuit i have found quite a few similar designs. i will try and change the value of r22 to 33 ohms and see what happens the diodes are fine.
    Dec 2009
    Devon, UK
    3,007
    Received: 281/1
    Given: 265/1
    Yes, one is 33 and the other is 47. I didn't spot that. I expect that they experimented with the values and that is where they ended up. I agree that you can change them to alter the bias and it is probably a better way to do it but be aware that it's much more sensitive to the values. Bigger resistance will lower the bias.
    Jun 2007
    609
    Received: 4/0
    Pignose Industries was basically born from a bright idea to fit circuit board of a cheap transistor amplifier kit inside a wooden cologne box. But to produce a "real" amp like the 30/60...
    ...well they had to outsource that and the job went to this fairly unknown little boutique called the "Quilter Sound". Many of us know that Quilter Sound eventually became QSC, and that in his late career Patrick Quilter returned back to designing musical instrument amps and started the Quilter Labs.
    This explains the utilisation of grounded collector topology (popularised by QSC amps) but perhaps more interesting is that "zero crossing processor", "soft clipping cell" and "current feedback" elements described in pending patent(s) of Quilter Labs LLC (e.g. http://oi57.tinypic.com/zjjus7.jpg) are already featured in this nearly 40-year old design.
  12. #12
    Dec 2008
    Wernersville, PA
    12,452
    Received: 181/2
    Given: 84/0
    hi
    Repost link to the schematic: http://music-electronics-forum.com/a...ose-7-3060.pdf
  1. ROLAND BOLT 30- 60 cycle hum...
    By czech-one-2 in forum Mods & Tweaks
    Last Post: 01-10-2015, 08:17 PM
  2. Pignose Swallows 30 Watt Speaker
    By soundguruman in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-13-2012, 03:27 AM
  3. Help with marshall jtm-30 & 60
    By Force235 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-27-2008, 11:14 AM
  4. Pignose B100V
    By Teleman55 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-09-2008, 06:51 PM
  5. Pignose 30/60
    By paulh in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-02-2006, 03:37 PM
