Results 1 to 7 of 7
Thread: Schector 1979 P bass pickups
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    Anyone have any idea how these Schector p-04 tapped coil Pbass pickups were wired?
    Apparently these were what Roger Waters used back then and they were designed or wound by Tom Anderson. Supposedly 12000 turns of 42awg and center tapped at 4.-k per coil or 8.-K.
    I'm guessing that the white and black wires on the right hand side were the full coils and the lift side pairs were the secondary? or perhaps they were both secondaries. The system connected to a switch to split them or go from series to parallel, it's not clear. There also seems to be an active module on the back of the switch possibly that ran on 9V
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,315
    Received: 206/21
    Given: 215/9
    Here's a picture of a piece of one.
    https://encrypted-tbn0.gstatic.com/i...UUUwIgrz9uWNmF
    It is hard to see the colors.
    “When you find yourself in a hole, quit digging.” WILL ROGERS
    Keep Rockin! B_T
    Jun 2014
    Melbourne Australia
    206
    I have quite a bit of experience with old schecter guitar pups... maybe I can help
    could you post a clearer pic of the back of the pickups and the wires coming out?....
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    Thanks Mr Fab, I don't have them in hand, I was helping someone on another forum who's not terribly handy with a camera. i did find a better photo of the backsides on this unrelated thread at talkbass https://www.talkbass.com/threads/vin...ckups.1186961/ it the first photo in the first post.
    Here: https://www.talkbass.com/attachments...19-jpg.733229/
    It's not going to get any clearer than that.
    Jun 2014
    Melbourne Australia
    206
    i'll take a stab:
    bottom half, red is full tap, white is centre tap, black is earth (earth also shields the pickup)
    top half: purple full tap, yellow is centre tap and brown is coil end
    so hot config is purple to hot, brown to red, black earth
    tap config (cool tap) yellow to hot, brown to white, black to earth
    these are series config (normal pbass)
    for parallel hot
    purple and red to hot
    brown and black to earth
    others disconnected
    cool config
    yellow and white to hot
    others disconnected
    you could easily have a switch to tap the pup and another switch for series/parallel
    good luck
    fab
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    Thanks Fab,
    Someone named imdkoz on talkbass actually had a Schecter P-bass prewired pick guard on his bass and kindly took the following photo of the switch wiring for me:
    Of note! The brown wire isn't really visible but it goes to the ground lug on the back of the pot along with the black wire.
    Jun 2014
    Melbourne Australia
    206
    I see
    that wiring is for the coils in parallel and the switch selecting the cool and hot taps
    series/parallel switching would add a little complexity to that arrangement
    but if he is happy with parallel, then fine..... but I do believe they were intended to be wired in series though.
  1. Musicmaster Bass Pickups
    By John_H in forum Pickup Makers
    Last Post: 12-28-2015, 07:13 AM
  2. Replies: 15
    Last Post: 02-12-2014, 01:42 PM
  3. Came across this (Bass Pickups)
    By Sock Puppet in forum Pickup Makers
    Last Post: 07-21-2013, 12:52 AM
  4. Tell me about P-Bass pickups...
    By FunkyKikuchiyo in forum Pickup Makers
    Last Post: 08-22-2009, 11:00 PM
  5. 1979 Peavey Bass 400 MarkIII
    By Swampy in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-17-2008, 05:56 AM
