Hi everybody. I own a mesa boogie prodigy and about a week ago starts making a crackling sound with all pots down. So i replace the power tubes, clean the sockets, but the noise it still there. i used to repair some solid state amps, but this is a little different. Can you guys give some tips...
Mesa Boogie Prodigy
Welcome to the place.
Originally posted by Simpson View PostHi everybody. I own a mesa boogie prodigy and about a week ago starts making a crackling sound with all pots down. So i replace the power tubes, clean the sockets, but the noise it still there. i used to repair some solid state amps, but this is a little different. Can you guys give some tips...
Did you check/clean the sockets of the driver tubes? I also assume that you set the bias when you replaced the outputs.
The last thing that I can suggest is to try changing the 3 12AX7 positions to see if there is any difference in the crackling.
I believe that because that amp is still being produced, there are no schematics available to non-authorized people. I guess that you can still try and contact Mesa to see if they will send you one, because the next step would be to start checking power supply components.
