Roland A-88 Mainboard Schematic Request
  • Roland A-88 Mainboard Schematic Request
    Hi.
    I need a schematic for the Mainboard of the Roland A-88. [5100029700]
    Specified i need the values for R9, R10 & L8.
    I broke the USB-Port when the keyboard hit the wall when USB was plugged in. :-(
    Thank you very much for any help.
    Greetings from Germany
    Here is a crop of a typical Roland midi port.
    Roland Midi Ports.pdf
    The IN resistors are 120 & 100 ohm.
    The OUT & THRU are 220 ohms.
    The Inductors are N1608601T01 made by Maruwa.
    N1608Z601T01.pdf
      Thank you for the fast answer.
      In this schematics the USB port is not shown.
      Maybe someone has an A-88 too and could take a photo of the Board.
      As I see it, the resistor values are printed on the parts.
      Roland support says that they are not able to tell me the values... A new board would cost around 150€ and thats really disappointing.
      The missing parts cost only cents... :-(
        OOOps.
        I had a senior moment.
        (Hey give me a break! I just turned 60)
        As I was working on a midi controller, I saw your post & thought.....MIDI.
        Anyway, try this.
        Roland USB.pdf
          60 isn't old. You gained wisdom and now have the time and serenity to enjoy life
          Thank you veeeery much, this should help me out. I'll give feedback if I get the mainboard working again. Thank you so much and have a nice day!
          I have to do some soldering now
          Marcel
            Marcel
            Here is the USB port of the A-88.
              So it appears that R9 & R10 are varistors.
              Panasonic Varistor.pdf
                It worked!
                R9&R10 should be varistors (for first tryout I didn't replace them at all) and for L8 I just soldered a 0kOhm resistor (as it should just be a bead inductor).
                My PC recognized the A-88 again
                Thank you so much doctor and and Jazz P Bass!
