Hey everybody!
I just joined the forum to find some help with my Crate V3112. I already posted these questions in the Gear Page forum but discovered the music-electronics-forum afterwards, which seems to be more appropriate to my needs :-)
So, here we go:
First of all I have to say, that I'm familiar with the potential hazards which come with working on Tube Amps, I know how to discharge the filter caps etc. I've built and designed several effects pedals during the last years, so I'm used to working with electronics and schematics.
First problem with my amp: There's always some noise on the clean-channel. It's more of a hiss than a hum and it's always present, even when there's no guitar plugged in. It always sounds the same and its level rises with the increase of the volume. In the crunch-channel there isn't this exact noise. It's a ittle bit noisy too, because of the stronger amplification, but this sounds quite normal to me.
Any suggestions on this?
Second issue: It seems like there is some problem with the grounding. Yesterday, I tried using the Line Out of the V3112 into my DI Box and record it but when I plugged the plug from the Line out in the DI there was just hum. Then I unplugged it and when I touched the plug I felt some voltage through it. I also felt some voltage on the guitar strings. Then I plugged the guitar directly in my DI Box, which was powered from the supply of my effects board. One of the effects on the board was still connected to my amp with an instrument cable so the effects power supply shared GND with the amp. I just got a loud hum through the DI Box until I pulled the cable to the amp out of the effects on my board.
The Amp itself works fine and I use it every day. Also with effects it's no problem.
Does anybody here have an idea where I could start? I disassembled the amp and had a look at the PCB and all the parts inside. They look quite normal. Two resistors look like they've gotten very hot, but they seem like they're still doing fine (R21 and R60). I also checked if the Effects line out GND is connected with the mains GND ---> yes!
Schematics are attached. This should be the right one but I am not 100% sure about this.
Btw, I am in Germany, so this thing runs on 230V/50Hz mains voltage.
Any suggestions are much appreciated!
cheers, iefes
So, here we go:
cheers, iefes
