5f1 kit distortion and low volume after kit build
  • 5f1 kit distortion and low volume after kit build
    I have checked all the wiring switched out the tubes and cannot figure out what is wrong. When I turn the volume control up I hit a spot at about 75% of the way up where a get a sort of squealing sound then no output after that. below that point I have output but distorted and very low volume.
    Any suggestions would be greatly appreciated.
    Lee
    Sounds like you have a parasitic oscillation going on; when you hit that spot on the dial, it's swamping the signal. Which kit did you build, did it provide a layout, and did you follow it? Can you post a schematic and any docs that came with it?
    PS: keep only one thread open; first, it's bad forum manners to run three concurrent threads, and two, it keeps the flow of information & progress all in one spot. Thanks!
    Justin
      Justin
      Thank you. Here is the layout.http://www.tedweber.com/media/kits/5f1_layout.jpg
      Sorry about the multiple threads I am new to this and had a hard time finding what I thought was the right place to pose my question. I will go back and delete the duplicate threads.
      Lee
        Justin
        I also built a Hoffman kit with a weber W022772 power transformer and got no sound at all.http://el34world.com/Hoffman/files/Hoffman_5F1.pdf
          Try reversing the red and blue wires from the output transformer.
          Stick with fixing the Weber for now, once it's good you can start a new post about the Hoffman.
            Thank you, that solved the sqelching problem at 75% volume. However, the problems of low volume, distortion and no output above 75% volume remain.
