line 6 spider 3 15watt pot
  • line 6 spider 3 15watt pot
    I've got a line 6 spider 3 15watt the phaser pot is broke off. Schematic says 4.75k d shaft pot r33
    Where would be a good place to find a replacement pot?
    Thanks,
    nosaj
    http://bmamps.com/Schematics/Line_6/...ice_Manual.pdf
    Full Compass should be able to assist you.
    If you do not see it, call them.
    Line 6 Replacement/Service Parts | Full Compass
      If that fails, upload a picture and we might be able to find something.
      Edit: I just looked at the schematic thinking 4.75K is an odd value for a pot. I'm not sure you have the right info. R33 is a standard 4.75K resistor- not a potentiometer. Most of the pots I see are 10K linear, although they lack labels. I'm not sure which one is phaser. You might double check your info.
        [QUOTE=Jazz P Bass;421347]Full Compass should be able to assist you.
        Found it and rechecked Schem and its really 10k. This pot will work.
        Thanks,
        nosaj
        Line 6 01 48 0001 Pot for Spider III Series | Full Compass
