Hi , I am very new to this Forum and I hope to find some help with this amp I have.
I Have a Markbass Little Mark II that is switching on no problem , preamp section works , DI works but I don t get any signal to the speaker.
I checked cables etc, Speakon connection, jack connection everything ok but no signal.
Before I had a few times where I had this issue , everything switch on fine but no output from the speaker.
So by switching on and off the amp I would manage eventually to get the signal back.
Then one day nothing....
I checked also the connections of the speakon to the main board and it appears to be ok.
No burnt components.
Anyone with some good advice ?
Thank you very much
Thank you very much
