wondering what this is ?
  • wondering what this is ?
    picked up an amp twin el84 tubes fender/sovtek in a gray and red cabinet maybe a pre amp ? ? will post pics
    https://scontent.xx.fbcdn.net/t31.0-...45208094_o.jpg
    most like just an amplifier would be a hell of a preamp using 2 el84s.
    nosaj
      Just looks like a low power generic amplifier. Looks like it might be home made to me.
        https://www.facebook.com/photo.php?f...0907997&type=3
          Spitfire clone?
          Guts pics! Guts pics!
          Justin
            Sure looks like a Spitfire on the inside to me... nice little amps! A lot cleaner than my two, too...
            Justin
              Justin
              I much rather like the method in the madness looks in the point to point ones I've built.
              nosaj
                Looks like an old PA converted to an 18 watt Marshall variant. Spitfire, whatever. I would bet it was originally a 6v6 amp. Probably screams if you put a Tube Screamer OD pedal on the input and run it through a decent 12" speaker. You might get a little more out of it by replacing the tube rectifier with bridge rectifier if the B+ is on the low side for el84s and may have enough heater current for another pre tube if you are interested. Certainly a lot of real estate there.
                  Nice H2 and RD!
                    It's a really nicely built amp, congrats on a great acquisition.
                    The master volume is post-phase-inverter.
                    EDITED: I'd suggested bypassing the cathode resistor with a 250 uF cap, but I think that's what the last cap on the board is doing
                    Valvulados
