Hi folks I have a 1973 MV Twin Reverb. I recently noticed the tone was a little less than I am used to. I stuck my head down and noticed only one speaker working.
I checked all connections with a DMM and all seem fine. I am running JBL K120 speakers with the quick spring push wire connectors. I tinned the speaker wires
to ensure they are solid. Continuity through all speaker connections to 1/4 jack on amp are good. Next I noticed that by switching the amp power off, and back
on, both speakers will work for sometimes 10 seconds, sometimes longer, some times less. Then 1 speaker only cuts out. Also odd is sometimes the left speaker will cut out, other times its the
right speaker that will cut out.
I pulled the chassis today and checked the back side of the jack, looks good and clean. All wires look good. Double checked all connections in the amp. All look good.
Before I try swapping speakers out, I thought I would measure the resistance on both sides of the windings of the OT, just incase
something showed up there. I unsoldered the connections to take ohm measurements. Input side between blue/brown wires I measure
73 ohms. Output side between green/black wires I measure 0.3 ohms. I am not familiar with what these winding measurements should be.
Before going further into speaker testing, do these OT winding measurements seem ok? Normal? Schematic here for convenience.
http://www.thevintagesound.com/ffg/s..._100_schem.jpg
Thanks in advance. Keith
