Front panel Pot Placement
  • Front panel Pot Placement
    I have limited space on my Hohner chassis Tube Conversion build.
    If I use treble, middle, bass, and presence, the presence will be quite close to the PT.
    I'm considering dropping the middle control and just having treble, bass, & presence.
    Will I miss the middle control in the tone stack, or is it mainly window dressing anyway?
    I realize that fender has done treble, bass, for years, but I have no experience with that setup!
    T
    I don't think you'll miss it, you can always adjust the value of the mid resistor to your liking. Do stacked pots stick out too far for your liking?
      I was considering just hard wiring a mid resistor in place, or put a trimmer inside the cab.
      The problem with stacked pots, is most of the pots are different values.
      using this tone stack.
      http://www.drtube.com/schematics/marshall/1986u.gif
      I could replace the 25k pot with maybe 2 -13k resistors.
      Or some sum of the two?
      Most of the time once I get the tone stack adjusted it never gets changed much?
      Thanks,
      T
        You could use 9mm pots and small knobs e,g Davies 1900H series (12.7mm dia) . Pins on this example rather than solder tags but that is not a deal breaker.
Name:	knob 12-7mm.jpg
          With your trim pot idea, you could always make it accessible from top or bottom side rather than on the front panel.
            Thanks guys.
            I have all the holes drilled in the faceplate except the last one.
            I think I will get it all working, and if the presence has no noise issues, wired temp near the end?
            Then I can cut the hole for it, and all will be wired normal.
            If worse comes to worse, like mentioned, hard wire on the board, or use a 25k trimmer wired on the board.
            Thank you,
            T
