Having trouble finding problem with power. Never has been an issue. Just turned on yesterday and no power. Fuse is 5 amp fuse is good. when turning on, it shuts right off.
Roland JC-120H
Originally posted by llanier0899@yahoo.com View PostHaving trouble finding problem with power. Never has been an issue. Just turned on yesterday and no power. Fuse is 5 amp fuse is good. when turning on, it shuts right off.
When you say it,'it shuts right off' do you mean the fuse blows? You can try pulling the secondary fuses and see the the primary fuse still blows to test the transformer.Last edited by nickb; 06-21-2016, 09:17 PM.Experience is something you get, just after you really needed it.
This schematic shows two mains fuses.
http://www.freeinfosociety.com/elect...C120-JC160.pdf
You can try measuring the resistance of the two line blades of the power cord.
With the power switch On, if all fuses & the cord are good, you should be measuring the power transformer primary.
Originally posted by llanier0899@yahoo.com View PostNot sure if yr. Im thinking 80s. The 5 amp fuse isnt blowingOriginally posted by llanier0899@yahoo.comFuse isn't blowing, when plug it in. My led light blinks and thats it.Experience is something you get, just after you really needed it.
That's right , they build them like this !!!
Czechoslovakia has 240/230 power.
The pcb mount 5 watt wire wound resistors and the bridge rect. fuse board lead me to think its this one.
SM_JC-120_4th ed ~March 20 -79.pdf
Well, I'm the one on here asking for help, so hopefully somebody more qualified than me can help you. You mean your fuses are white,not clear glass? Thats ok,they make em like that. Unfortunate;y you cant see if those ones are blown or not.Fuses are cheap so go ahead an replace them with the same rated fuses. It may spring back to life. If not, then you eliminated one possible problem...
