roll your own vacuum tubes
server seems to be down right now. what bad luck."Stand back, I'm holding a calculator." - chinrest
really? How about these? (the indiv. links)
all sorts of interesting looking stuff. Grid winders, some glass distortion meter thing, some old equipment, etc.
http://www.pandcamp.com/tube_pandc/1.htm
http://www.pandcamp.com/tube_pandc/2.htm
http://www.pandcamp.com/tube_pandc/3.htm
http://www.pandcamp.com/tube_pandc/4.htm
http://www.pandcamp.com/tube_pandc/5.htm
http://www.pandcamp.com/tube_pandc/6.htm
http://www.pandcamp.com/tube_pandc/7.htm
http://www.pandcamp.com/tube_pandc/8.htm
http://www.pandcamp.com/tube_pandc/9.htm
http://www.pandcamp.com/tube_pandc/10.htm
funny, i can't get the server to respond. maybe there's a router problem or something.
here's their listing at network solutions. don't know why i can't reach them.
http://www.networksolutions.com/whoi...n=pandcamp.com"Stand back, I'm holding a calculator." - chinrest
Works fine from here and has since the first few moments of the first post.
Note that the site wants to install a language pack, which I declined, but depending upon your o//s or browser settings it may come up as something different. IF there's a message, read it carefully as it may actuallybe getting through.
You can try to ping the site from the command line to see if anything is getting through.
Very interesting site though.
Barry
Dai, please can you tell me what the captions to the pictures on this page say
It looks like the guy is making plasma in a tube with an induction heater."Enzo, I see that you replied parasitic oscillations. Is that a hypothesis? Or is that your amazing metal band I should check out?"
where do most of you get your tubes from??? like 12ax7, at7's, 6L6', 7025's,,,,,
like who sells the best quality tubes like these I've mentioned??? I can get most of them from a couple of local guitar shops here but
I'd like to know where you guys recommend to buy them from???
popoahi
Some links to mass producing valves.
Mullard - The Blackburn Vacuum Tubes Factory (Full) - YouTube
Tube manufacturing in the 40's | MAKE
