I am in the process of rebuilding my gutted PRRI to a AA1164 layout. I am trying to get the reverb send/return RCA jacks as well as the verb/trem foot switch 1/4" trs jack hooked up correctly. The 1/4" trs jack is what comes stock on the PRRI so I am just reusing it in stead of the second pair of RCA jacks found on the original PR. The stock PRRI is wired slightly different using 4 (221) resistors. So I am not sure I got wiring right using the new aa164 layout. Is there something else I am missing here?
PRRI: Rewiring reverb send/return & verb/trem footswitch to original layout???
Yes, if you are basically just replacing the RCA jacks with the TRS 1/4" jack, then you right on.
I'm not as smart as all of you guys, I can't seem to memorize all of the different versions of circuits. In order to answer you, I had to find schematics for the reissue Princeton as well as the AA1164.
