Marshall AVT100 Valvestate 2000 PCB switch
  • Marshall AVT100 Valvestate 2000 PCB switch
    Anyone know where I can get a replacement for the OD1 switch used on the AVT100 preamp? I pulled the switch apart accidentally. The switch is a momentary contact with and LED built into the side of the switch. THX
    Marshall still do them. I got one a few weeks back.
      I performed some surgery on the broken switch and since I only need one side to work I got it to work again.
      Where did you get the switch?
        That would make you a switchdoctor, would it not?
          Directly from Marshalls
