I know very little about electronics, and thought I'd ask the question here, before I fry my amp.
I want to bypass the Roland's preamp and access the power amp directly. I use a 12 channel mixer mounted permanently to the side of the Roland amp, and plug the output of the mixer into a channel on the Roland. I know this isn't ideal, as the signal is traveling through two preamps. I actually did this mod on a Behringer amp, and it worked out fine. That said, this is a much more expensive amp, and I don't want to chance screwing it up!
The schematic shows CN4 from the preamp to the CN9 connector on the amp, with 4 leads. Am I correct in assuming the white lead is the positive and one of the blacks is the ground. Would tapping into the leads at this connector give me what I want, or is CN4/CN9 not the right connectors? Thanks for any help....
