Mind print DTC Tube compressor calibration fault
  • Mind print DTC Tube compressor calibration fault
    This one is beginning to do my head in.
    It came in to me a while ago for a switch problem, Fixed that the owner said that one of tone filters wasn't working
    I sorted that it was a pot. He always said it works ok but does not think its working 100%
    Compressor_adjustment_E.pdf
    Mindprint _DTC.pdf
    Anyway on final test i noticed that Channel B when you turned the compressor on it wasn't compressing at the same as ChA
    This is done with same signal injected into both with all the tone/filters off and Compressor levels all the same.
    When you check output without compressor on. Both outputs are prefect
    If i turn the Trim pot TR1 on both channels full clockwise i would expect that the signal output would be roughly the same but CHB is higher. Both sets of LEDS are spot on. I knew there is some adjusters for the LED display. They are working
ID:	870826 Channel A is the top
ID:	870827 without any compression
    Replaced both tubes for brand new ones
    This unit has had a lot of repairs in the past and is a nightmare to work on. One main board and 3 sub boards . Lots of ribbon cables hard wired and one end and connectors at the other. Ive gone thought the hard wired connectors and remade most of them. Very hard work trying to work on and scope out and compare, I don't have brilliant test kit. I have checked that its not my scope etc
    Not sure if im doing anything wrong, but im sure there is something wrong. Out of my comfort zone
    please if anyone can assist
    Bassman
    Looks like nobody's going to help me ?
      Have you tried chasing the signal through the channel B and comparing each node to channel A circuit? You might want to bring this topic over here since it really is a "solid state" (i.e OP amps) design with some tubes in the output: Amplifier Discussion
        Ive sort of tried, But the layout makes in very difficult due to the 3 sub boards . was hoping for a few idea's on looking at the map on where to look. I will make another tread in the forum above.
        Bassman
          The 'limiter' appears to be IC 7.
          There are a few switches that have to be made for it to receive the correct signal.
          Prove out the switrches first.
          Then, I would recommend looking at IC 7's output & comparing it to the working channel.
            You are a star Jazz P Ive been avoiding this for weeks today i decided to take a look and i had forgotten what channel was missing behaving and looked at chA
            and i saw a very small solder splash across a switch and now i can calibrate it and it working correctly.
            Hopefully none of the ribbon cables have bust
            Bassman
