HB bobbin mold pics
  • HB bobbin mold pics
    Thought you guys might like to see these. The mold is in polishing and adjustments for slug fitting now. First samples are in, and they look great! (even without a polish on the mold)
    Dude, that's cool! Can you make me some in cream?
    So, are these standard dimension bobbins, or did you push/pull some measurements here and there for your own needs?
      Beyond cool
      Congratulations on investing a good amount of $$$$$$$$ into those dies .
        Cream or "Ivory"?
        Take Care,
        Jim. . .
        VA3DEF
        ____________________________________________________
        In the immortal words of Dr. Johnny Fever, “When everyone is out to get you, paranoid is just good thinking.”
          Originally posted by kayakerca View Post
          Cream or "Ivory"?
          Do I hear "tan" or "beige"?
          DON'T FEED THE TROLLS!
            Good Job Wolfe!
            T
              Yes I can. And white, too. And pink, green, blue, or any other color in just about any material. Minimum orders would apply to custom colors, though.
              Butyrate, polycarbonate, ABS, Nylon, Glass Filled Nylon...
              The Polycarbonate black is VERY BLACK.
              These are not an exact PAF replica. They're not meant to be - they're meant to be VERY nice bobbins. They're a replica of the Allparts/StewMac bobbin with a few improvements. The bottom lead-out hole has been made round instead of square, so the lead wire does not catch on the "ledge" on the square when putting it through. Always an annoyance for me, so I drilled them out.
              The knit-lines between the poles are dramatically reduced. It is possible to eliminate them altogether.
              The plastic sinkage between poles is reduced. Possible to eliminate completely.
              There is ZERO flashing that needs to be sanded off in order to wind. The Allparts bobbins began to get larger and larger burrs on the ends of the flanges quite a few years ago.
              Hole diameter for the slug-side bobbin is being reduced to a PROPER .187 diameter. Allparts were oversized for metric. .187 slugs only worked because of the compression ledge at the bottom of the hole.
              Polycarbonate and Butyrate will shrink down to virtually a perfect 49.2mm spacing.
              Solid core. None of that flimsy hollowed-out core crap.
              They will ship on sheets of sticky-backed paper to protect the top surface. IE: NO SCRATCHES OR SCUFFS.
              No unsightly large gaps between bobbins when mounted onto a standard base-plate. (I've always found PAF bobbins to be too narrow, creating a canyon between them - YUK!)
              These are being made by the same people who do bobbins for Duncan.
              Next up, base-plates!
                Beyond cool
                Total cost of mold was nearly $15,000.
                  Maybe only $$$$$ ?
                    What's the core dimensions on these, if you don't mind sharing?
                      I'm not at home right now to measure these, but it'll depend on the material, too.
                      Like I said it's not an exact PAF replica. And it's not meant to be.
                      These drawings were made from an Allparts bobbin years ago. The mold was made for ABS. Due to shrinkage, parts made in Butyrate and Polycarbonate will be very slightly smaller. By about .011 in overall length, shrinking down to a near perfect 49.2mm.
                        Hahaha. HAHAHAHAAH.
                        So... back when Allparts changed their bobbin without telling anyone, I had sent the order I received back to them for replacement with the old style bobbin. Y'Know, cause the new ones suck.
                        This was way back in March. Allparts was supposed to get the old style bobbins back in stock in about 8 weeks. They never did.
                        So in the meantime, we get this mold made. And now that it's finished, I was going to go ahead and cancel the replacements with Allparts, and get a refund. I had held onto the order just to be on the safe side, cause I was so low of black bobbins.
                        We left for a week to New Mexico. Now that the mold is finished and about ready to produce, I come home to finally find.... about 1000 replacement bobbin sets from Allparts.
                        Well. Poo.
                          Great job Wolfe!
                          Whenever I get my bobbins molded I'm always shocked by the quantity of plastic that gets wasted in the T portion of the mold where the plastic is injected. No way around it though.
                          They don't make them like they used to... We do.™
                          www.throbak.com
                          Vintage PAF Pickups Website
                            Originally posted by JGundry View Post
                            Great job Wolfe!
                            I would think they'd recycle it. Grind up, use again. Maybe?
                              Probably .... at least itīs already the right colour and composition
                              In any case, these are very efficient; I hate seeing small parts injected where the useless "tree and branches" are way larger than the useful "leaves"
                              But parts are what they are.
