Originally posted by trobbins
View Post
ac ripple on screen grids Ultralinear
Originally posted by trobbins View PostI think that means you have about 450V B+ and 40mA for about 18W plate dissipation per KT66. Using PSUD2 indicates the B+ ripple voltage should be about 12Vpp, or circa 4Vrms, with a 60uF cap and that power transformer secondary and a 5U4G.
Sounds like you have a bad part, or wiring, or your measurement technique is not right.
If your caps can withstand 550VDC, or you have a variac, then you can firstly check the unloaded B+ for DCV and AC ripple, and a steady reading.
Originally posted by Rob's Radio-Active View PostNo, the PT can't cause ripple by being too powerful, but the filter circuit can be too "small" for a given load current. I hope that makes sense.
cheers
RobLast edited by Rattler66; 09-11-2016, 02:14 PM.
Try the bias balance pot by ear. Due to circuit anomalies minimum hum may be a setting which does not perfectly match when measuring idle current.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Are you sure that the taps are definitely intended for UL?
eg given the jtm45 / RS Deluxe thing, they may be 8k taps.My band:- http://www.youtube.com/user/RedwingBand
Perhaps it is easier to add a 1 ohm current sense resistor in the cathode circuit of each KT66. Your meter should read about 40mV across each resistor (ie. 40mA bias current in that KT66). If you don't have a good meter that will read with 1mV resolution, then use a 10 ohm sense resistor. That reading should be stable - if it isn't then you have other problems to track down first and foremost.
You could clone the existing bias supply circuit so that you have two seperate bias voltage circuits. Split "D" so that each bias circuit feeds just one of the KT66's grid leaks. That is the least risky path to take. Trying to use some of the existing bias supply components to generate two variable bias voltages will change the voltage levels and time constants and bias ripple, and need some assessment and juggling.
Originally posted by trobbins View PostPerhaps it is easier to add a 1 ohm current sense resistor in the cathode circuit of each KT66. Your meter should read about 40mV across each resistor (ie. 40mA bias current in that KT66). If you don't have a good meter that will read with 1mV resolution, then use a 10 ohm sense resistor. That reading should be stable - if it isn't then you have other problems to track down first and foremost.
also the reading at the cathode (I did install the 1ohm) is steady but the plate voltage isn't, not when the humming starts
Grounding
The schematic shows the HV CT (the noisiest ground)(1) connecting to the preamp ground (1). Never a good idea. The HV CT should go to (2) where the reservoir cap grounds. If possible the HV CT should go directly to the cap and a separate wire from the cap to the chassis. The (C) node filter cap should ground to the preamp ground (1). The bias supply filter (3) and the power tube cathodes (5) should go to (2) or close by. The ground connection for the heater CT might cause noise in the preamp if grounded there. This depends on parasitic coupling within the transformer. Try it at (1) and (2) and use the one that is lowest in noise. Ground for the output transformer should go the the speaker jacks with a separate wire to the chassis.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
