View Post
Why does this amp sound so good?
Originally posted by GainFreak View PostI've heard complaints about someone using slotted head screws instead of Philips type
A bigger case can be made on guitars. Nothing makes me more nervous than when I'm working on someone's $8k-$10k+ historic LP and I'm adjusting pickup heights with slotted screw heads......
Originally posted by wizard333 View PostThe channels aren't run in parallel, and the channels are quite effectively isolated in that configuration, so that isn't it.
Check out this article: Vox AC30 MYTHS ? Tone Lizard
Towards the end he is describing that part of the AC-30 tone is the feeding of the tremolo channel into the PI (instead of having the second PI input grounded as in most amps). I was thinking that some similar stuff could happen here.
Looking at the preamp nothing jumps at me that could impart a special tone (that is, more special than other preamps out there).
I see what you're saying, but note, also from that article, this point:
" As long as the Volume control is set to ‘0’, the grid is at AC ground. "
And so it is on this amp as well. The volume control on the EF86 channel has no audible effect on the 12AX7 channel, and is generally kept off when running the other channel as the way they have the inputs set up necessitates this for noise purposes.
OK, but having the grid at AC ground doesn't make the NFB more effective (and Vox doesn't even have one)
For instance, look at a typical fender schematic (with NFB values similar to yours), like
http://www.thevintagesound.com/ffg/s...b763_schem.gif
The signal from the speaker is attenuated by 820/100 divider and then fed directly to the lower PI tube grid (as well as the tail), where it's amplified by like 25 times and mixed with the signal from the preamp. If I remember correctly, it's already been argued that it doesn't have to be fed to the tail at all, but it helps the balance somehow (don't remember exactly).
Both of your PI inputs are used up by channels, so there's no place to feed the NFB signal.
Someone correct me if I'm stupid
Originally posted by frus View PostOK, but having the grid at AC ground doesn't make the NFB more effective (and Vox doesn't even have one)
As noted, the NFB circuit is irrelevant because it is switchable and does almost nothing, so I just leave it off.
Originally posted by J M Fahey View PostTheir market is Musicians who mostly don´t have much use for a schematic either because they plain can´t *read* them or best case can read but not analyze them (as in : "hmmmm, so the tone stack is driven by a cathode follower, that means it will follow more closely the curve that TSC shows" but can follow a "paint by the numbers" layout, which is exactly that, they show not only coloured wires and their path, but even resistors identified by their colour bands.
And drawn jacks instead of showing the internal leaf switch connections and so on.
Not a bad idea, I guess it expands potential market base by, say, 10X ... yet they *should* offer a schematic anyway, doesn´t hurt and worst case can be ignored by those not interested.
Oh well.
Gain:
The 1M/500pF doesn't have the usual 470K to ground so you pickup 6dB of gain that is normally thrown away on treble peaking. That and the EL84s have significantly more gain (6 or 8dB) than what you see in a Plexi. The 56K on the cathode follower lowers the headroom by rounding off the top of the waveform and that will give more distortion as the Master is turned down. The feedback switch only feeds the tail resistor, I'm surprised it does anything at all.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by Enzo View PostWe'd be more clever if we had a schematic to look at. Can you link one in?
EDIT: The first version had errors. I replaced it with this corrected one.Attached FilesLast edited by nickb; 09-17-2016, 06:36 AM.Experience is something you get, just after you really needed it.
Originally posted by wizard333 View PostThe channels aren't run in parallel, and the channels are quite effectively isolated in that configuration, so that isn't it.“If you have integrity, nothing else matters. If you don't have integrity, nothing else matters.”
-Alan K. Simpson, U.S. Senator, Wyoming, 1979-97
Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
https://sites.google.com/site/stringsandfrets/
I penciled this one out while I was supposed to be working earlier today. I got the following differences:
C5 .0022uf A significant difference.
R21 56K
R22 47K Another significant difference.
C15 330pf
C20 22uf/63V with the positive end hooked to ground.
R30 100
RV4 Pin 1 not connected, pin 2 (wiper) connected to RV3 pin 3. Reverses the action of the knob.
The Master Volume is missing between the tone stack and the PI.Last edited by 66 Kicks; 09-17-2016, 04:14 AM.
Originally posted by nickb View PostI had a stab at it. I didn't bother with all three taps on the OPT the PT or the GZ34 but I think all the important stuff is there.
Only slight difference I see is that R22 (bass slope) is 47k and R21 (cathode ) is 56k
OF COURSE, looking at an actual schematic shows what parts DO relative to others and the circuit makes sense, instead of just showing what goes where.
Thanks again.
PS: and might very well miss some other small differenceJuan Manuel Fahey
