Results 1 to 6 of 6
Thread: Crackling sound when played hard?
    Supporting Member StarryNight's Avatar
    Oct 2008
    Victoria, BC Canada
    402
    Guys, I'm looking for some advice as I've never come across this kind of problem before. I've got a late 50s Guild that has a bridge pickup that, when the low E string is strummed hard, the pickup crackles loudly. It doesn't happen all the time but when it does it's very obvious. Anyone heard of this problem before. I have started taking things apart yet so I thought I would tap into the hive mind first.
    Cheers!
    Old Timer
    Boston, MA area
    2,616
    Received: 3/0
    Sounds like static electricity on dry days. Is everything grounded?
    Dec 2008
    Wernersville, PA
    12,362
    Received: 111/1
    Given: 31/0
    Late '50's?
    The pickup potting may have to be redone.
    Nov 2007
    Barnegat,NJ
    560
    Received: 9/0
    Try this simple thing. Attach an alligator clip wire on the bridge and attach the other end directly to the ground on the output jack or plug to see if the noise goes down. If so, it means a bad ground wire connection from the bridge... an easy fix!!!
    Joseph J. Rogowski
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    Static can build up on the pick guard, try antistatic spray or a rubdown with laundry dryer sheet to see if that helps.
    Nov 2006
    Sacramento, CA
    503
    I had a similar problem that turned out to be the vibrations affecting the switch. That's probably the easiest possibility. See if holding the switch whenyou strum hard has any effect.
  1. Anyone have a sound clip of a 5D4 super pushed hard?
    By allsavy in forum Tweed Builders
    Last Post: 07-07-2013, 05:02 AM
  2. Sound drop-off when hitting high E string hard
    By Normybaby in forum Pickup Makers
    Last Post: 12-21-2010, 05:18 PM
  3. crackling sound in tube amp
    By musicman602 in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-29-2009, 12:39 AM
  4. crackling sound on my SF super reverb
    By qwixzh in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-01-2009, 11:45 AM
  5. crackling noise when playing hard
    By allsavy in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-05-2009, 05:13 PM
