Thermal compound, grease, heat sink paste
  • Thermal compound, grease, heat sink paste
    Need some general purpose thermal grease for transistors, voltage regulators, and the occasional computational engine. What's good, but in small quantities?
    Top of Amazon's brain is something like: https://www.amazon.com/Arctic-Silver.../dp/B000OGX5AM
    http://amps.monkeymatic.com
    Arctic Silver makes several products. I am not sure how something that is 99% silver can be non-conductive electrically.
    ANy electronic supplier you use, like Mouser or Digikey will have silicone thermal heatsink grease. Thermal compound, thermal grease, various similar names for it. Heat sink compound. I use GC brand, but that is because that is what my local electronics parts store carries. Mouser sells Chemtronics. Jameco sells GC:
    heat grease | Jameco Electronics
    I used "heat grease" as my search term.
    Digi sells Chemtronics and MG.
    Even Radio Shack used to carry it, maybe still does. If you have a local electronics parts store near you, they likely have it.
      Also MCM Electronics, even Fry's.... Heat sink compound. The white stuff.
        The trick there is that they state that whatever amount of silver in there is 99.9% pure.
        But I do agree, I don't want anything conductive whatsoever in heatsink paste, no matter how little there is of it.
          The last time I bought some it was from Radio Shack. A .25 oz tube for $2.00. Part #276-1372. Silicone and zinc oxide.
            g1, right again, I did not read carefully. It is made from 99.9% pure silver, it isn't itself 99% silver.
