Page 3 of 4 FirstFirst 1234 LastLast
Results 71 to 105 of 116
Thread: Mod'ing a tube circuit (from early 60's stereo turntable)
  1. #71
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Got you on the Mid-control; that's going in the soup!
    I have only observed things visually; I have yet to pull the whole PT section out. But i am sure that the black side of the AC is going to a large 'ground - looking' lug on the top of the xformer. That's all i'm saying. It's weird.
    I will try to get some photos together and also do some VM tests.
  2. #72
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Here's a quick photo of what I'm talking about...
  3. #73
    Senior Member TimmyP1955's Avatar
    Mar 2007
    Indianapolis
    422
    Received: 36/0
    Given: 21/1
    13
    The balance control is likely a log pot on one channel and a reverse log pot on the other channel, so this will need to be replaced. Unless: If you cascade the channels, the balance pot would be a distortion control with attenuation to keep the output level "kind of" the same at any distortion amount. You would also have pre-distortion and post-distortion EQ.
  4. #74
    Mar 2007
    Indianapolis
    422
    Received: 36/0
    Given: 21/1
    13
  5. #75
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Hi TimmyP1955 - i am so tempted to keep adding mods but i think i need to draw the line; this thing is getting crazy!! :-)
    Going to try to pull the PT section out today and have a closer look. Still bewildered by this black wire going to that lug on the top of the PT. Was hoping to start off with grounding the unit with the new power cable before going further.
  6. #76
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Ok, seems to be that the thing on the top and side of the PT that the black AC is connected to is a 'spring-loaded rose metal fuse'.
    Couldn't find any info on them in a few initial searches. No biggy, if it ain't broke i won't fix it.
    So, as for where to attach the ground of the new power cable, since this is a wood cab the only really obvious grounding spot i'm seeing available is where the speaker jacks are. Is this a good spot?
  7. #77
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    I seem to remember grounding my PS stuff to the cathode ground of my 6V6 on my (single-ended) 5F2A Fender Princeton build.
    Found a different service manual for this model, by the way:
    http://www.kevinchant.com/uploads/7/...231/ag9115.pdf
  8. #78
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Wired in the new power cable with plenty of slack on the ground wire to go wherever it needs to. Suggestions?
    Put in the 10k 1 watt in the power supply instead of the 18k, per Chuck-H!
    Most of the time went to trying to screw the PT back into the cab; tight fit!
  9. #79
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Hmm, so the 80ma fuse blew.
    I have only changed out the power cable and the 10k resistor in the PS per Chuck.
    Pilot light and tube heaters are still powering up. No sound/report on the speakers at all.
    It's a SS rectifier so maybe its the PS caps?
    Will pull tubes and power up with new fuse to see if its the power tubes.
    As always, open to input...
  10. #80
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    The fuse that was in there was rated for .5amps, not 80ma. Oye. It was vaporized inside and the end cap came off when i pulled it out.
  11. #81
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Changed out the fuses - back in business!!! I guess they were just too old.
    @ChuckH: Already a giant difference just from the change to the input section!
    I A/B'd the unaltered channel with it at full volume; no contest - clearly louder with much more body.
    (I used a 39k instead of 33k since that's what i had on hand).
    I am noticing a bit more life to both channels since changing that PS resistor, too.
    Yahooo!!!
  12. #82
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Ok, emergency post!
    I'm poised with soldering iron in hand, but....
    On the schemo C8 should be "330mmf" (330pf).
    The actual cap that i just pulled out is 3300pf.
    Should i still go with the 500pf cap here or keep the old one or go for another value?
    Wouldn't i want to go for a value higher than 3300pf to add more 'upper-mids'?
  13. #83
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Here is a little recording of the amp so you can hear where things are at.
    The first 20 seconds is the unmodified channel. From about 22 seconds on is the channel with the input mod done.
    (you can hear (and see from their waveform) that the mod'd channel has more articulation and starts to break up sooner yet with less compression)
    Anyway, regarding my previous emergency post, check out the 2nd one to get an idea of the 'brightness' of the amp at this stage, this link should take you straight to this 2nd take:
    https://soundcloud.com/user-34254870...nputmod#t=0:21
  14. #84
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    15,338
    Received: 2,316/4
    Given: 2,693/0
    30
    The treble circuit cap should be 500pf. Be sure you are targeting the right cap as per the schematic. There are a couple of 3300p caps in the stock circuit that are NOT the treble cap. It's possible a 3300p cap was mistakenly installed in the treble circuit too though. But it would definitely have been a mistake in the original construction if that's the case.
    Too early to listen to the clips in my home
  15. #85
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Ok, that's what i get for slingin' solder around late at night on xmas eve... I put that cap back, replaced the 'right' one this time!
    Also did the following:
    Changed out C9 (cut cap); Changed V1 cathode resistor; put V1 bypass cap on a switch; put neg feedback on a switch with a 2k instead of 1.5k.
    Here's a one minute recording i just did which demos each of the stages sequentially.
    1) Un-modded channel
    2) Modded channel with V1 bias resistor in play, the 500pf treble cap and the new cut cap to ground (what a HUGE difference already!)
    3) Now with the V1 bypass cap engaged
    4) Now with the negative feedback resistor engaged
    Its sounding pretty killer!
    https://soundcloud.com/user-342548702/demo2-2nd-wave
    yeah, i know, i'm probably the only guy on here today...
    happy holidays everybody!!!!
  16. #86
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Happy New Year to everyone!!!
    So today I finished all the mods (to one channel) except for the 500pf cap on the volume pot. Changes include:
    -Escherton's idea to put a pot in the tone-stack to drive the mids
    -Chuck-H's volume pot mod and also changing that cap that was attenuating LF's to the power stage.
    Holy cow this thing is screamin'!
    WAY more volume now.
    The mid-control pot adds a ton of flexibility. (Used a 500k log)
    Between the mid-control and the various switches for the mods it is doing a great job of being able to sweep from clean and punchy to dirty and growling.
    Exactly what I was after! Thank you guys for the incredible help and suggestions on this!!!! Couldn't have done it without you and I learned a helluva lot in the process.
    Remaining stuff: doing the same mods to the other channel, cutting the aluminum face plate, soldering up the power supply for the effects circuits and the circuits themselves. Still a bit to go on this little beast but it'll be a cool secret weapon!
  17. #87
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Ok, all the tube circuit mods are done to both channels. Yahoooooooo
    One last request for info on a Mod!!!
    In order to use the tube amp as an 'effects' device without the speakers, what are the options? 8ohm 5watt resisitor? cathode follower? tapping it before the power tubes?
  18. #88
    May 2007
    pacific north west
    15,338
    Received: 2,316/4
    Given: 2,693/0
    30
    If you like the way the 'whole amp' sounds then you'll want to use the whole amp. Since it's stereo you'll need to disable one side. You can put it on the same switch that engages a split resistive load to the other side. That is, a fat DPDT toggle wired so one pole switches the output of one channel from the speaker out to the resistive load and "recording" jack and the other pole does something like lift the cathodes of the unused channel. The split resistive load should probably be a higher impedance than the 8 ohm specified load because an actual speakers "average" impedance would be higher than that. At least that's become the common MO for resistive attenuators. So maybe a total of fifteen ohms split to send the required -10dB and/or +4dB signal to any effects depending on your requirements. You could use a 15R rheostat too and just adjust it until the effects unit/s are happy and the noise floor is optimized. Speaker emulation would be more complicated and I personally haven't found much happiness in my attempts, but there are supposedly some good products that can be put in the loop for that too. If the circuit sounds too flat and brash (like you're not using a speaker ) something that might help would be to use a series cap and a rolloff cap from the CT of the rheostat or the divider circuits. Something like starting to roll off LF around 100Hz and HF after about 6kHz. If you had, say, a 10R series 5R load divider the series cap would be 100uf and the shunt cap would be 4.7uf. That would seem 'nominal'?
  19. #89
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Chuck, you are a true beast of the tube wilderness - thank you very much for that explanation. I dug in a bit to know more and i think it's best that i just build a power-soak as its own device later on!
    So, with humble heart, i must confess that my 2nd channel (which i just mod'd to be like the first channel) is not working. I didn't check my changes as I went along by turning on the amp after each mod - i will NEVER do that again
    Troubleshooting time!
    - I have done continuity checks on all the mods and they seem to be connecting ok. (Wouldn't call this conclusive, though).
    - Swapped tubes from 1st to 2nd channel, no difference.
    - Checked voltages and compared them to the working channel - they all seem to be similar.
    - When checking voltages, I'm getting a report on the speakers from C12, so problem comes from before that i presume.
    - V1 tube socket a little dirty, but once i got it into place, voltages were correct yet no sound.
    - Getting normal voltage on the V1a plate.
    - Input section seems to be ok (input making it to the grid of V1a in continuity test)
    - Not getting much of a report back when i touch C8 with the test leads as i do on the 1st channel.
    So, i'm guessing the prob is between the input and the volume pot (R2).
    As sucky as this is, i'm really hoping to learn some troubleshooting techniques from it, so please feel free to throw me suggestions!!!
  20. #90
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    I have the most wonderful and embarrassing news all in one fell swoop! I wired the volume pot wrong - i thought it was cranked the whole time!
    Everything seems to be working good on both channels!!!
    I will try comparing the two soon and report back.
    Meanwhile, the dual 15v PS for the FX units is now wired up...
  21. #91
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    My main intention for this unit was for re-amping stuff that needed some pizzazz and was super glad to crank it up this weekend and do just that. I had a guitar line that even though it was tracked through an amazing 60's Bassman with killer mics and preamps in a great studio, it was lacking in upper frequencies. (crazy, i know) This box did just the trick! Was really cool to switch things in and out of the circuit and use that mid-boost pot to dial in the right sound. Yahoo!
  22. #92
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    A strange thing happened on the way to jamming out... One channel stopped working. DRATS!
    When I remove the tubes and test voltages I am getting a report from the speaker when I check the plate on the EL95.
    The issues I have found:
    1) Was very hard to get a reading for the 2nd plate (pin 6) of V1b with my probe, which fits down into the pin hole.
    2) Pin 6 showed 280v when I finally got a reading. Pin 6 of the other channel shows 265v.
    3) C12 is not showing any voltage at all.
    I'm going to:
    A) Clean the pin hole
    B) Check solder connections for Pin 6 and C12
    Anything else I should be looking for?
  23. #93
    May 2007
    pacific north west
    15,338
    Received: 2,316/4
    Given: 2,693/0
    30
    You may have a leaky cap putting voltage on the chassis. That's all I can think of to cause a report from the speaker with no tubes in. Did you install a chassis safety ground?
    The difficulty getting a reading from pin 6 of the preamp tube could be a short, a fault or just old grimy flux preventing good contact. One tip I read here was to sharpen the meter probes for poking through that stuff. I haven't done it yet but it seems smart. Check voltage on the other side of the 220k resistor connected to pin 6 If it's still troublesome to read you may have a problem with the voltage rail.
  24. #94
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Hi Chuck!
    Regarding the speaker report, it's when I test the plate voltage of the output tube. It does the same on the working channel, as well.
    I did check that 220k (R19) and it's putting out 280v. That's what's strange to me, the cap (C12) next to it is not seeing any voltage.
    Yes, i did put a grounded cable on it and tied it to the chassis.
  25. #95
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Ugh, been out of the loop for a while due to my first cold in probably 5 yrs... But i'm back!
    So, i did check R19 as i said, and its getting 280v. C12 is not seeing any voltage.
    I checked continuity from the tube socket to R19 and C12 and its just fine.
    Really strange to me and I admit I'm not sure what to check next on this thing!
  26. #96
    Feb 2010
    11,750
    Received: 1,610/23
    Given: 4,120/11
    22
    So there is 280V on one side of R19 and no voltage on the other side?
    Does it check out at 220K? Are both heaters lit at V1 ?
    Does V1 pin 8 measure about 3.4K to ground?
  27. #97
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Hi g1, thanks a lot for those ideas; I checked those and here's what I found:
    V1b on Good Channel - Pin 8 to ground: 3.5k
    V1b on Bad Channel - Pin 8 to ground: 3.5k
    R19 on GC: 200k
    R19 on BC: 220k
    So, then I re-flowed the solder over the pins and R19 and the dang thing is workin!!! Yahoo!!!! I guess something got jiggered loose during my mod work; though i did find a little component lead floating around beneath the circuit board which i removed, so it might have been that?
    Anyway, if my luck holds then there shouldn't be anything left to do on the PCB and i can go ahead and fix it in place.
    Just tried both channels with this knock-off Strat i just got for 30 clams, (my usual Strat-knockoff is a Samick that is really dark sounding, so it was nice to hear the amp with that crazy Strat chime). This amp kills it! Very different sound from my Princeton build, that's for sure. Apples and Oranges, though.
    Thanks again for everyone's time and expertise!!!!!
    Still working on the effects/mixer stuff that will go in place of the turntable. Having issues with the dual PS where it checks out fine (+15 / -15) when not under load, but the negative side is collapsing down to 2v under a test load. Tube stuff is so much easier to work on ;-)
  28. #98
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Time to WAKE this thread back up! Hi guys!
    This project is getting pretty close to completion!
    So I have been slowly tinkering with effects and also treating my steel sheet to the elements to give it some visual vibe for the front panel.
    So far I have built the following things to go in the box:
    1) Germanium Fuzz Face (2n527 transistors)
    2) Dallas Rangemaster (2n527)
    3) Two AMZ tone controls (the last one on his page, with boost and cut)
    4) Cave Dweller Delay (still working on this one)
    5) Almost forgot! I designed my own Muffer distortion that sounds really dang cool.
    I still have a few simple things left to build including the FX sends, 6 channel mixer, buffer units, etc.
    Something I really want to add is tremolo. But instead of doing a stand-alone solidstate effect, I wanted to ask y'alls opinion on how to do this:
    Solidstate LFO driving the cathode of V1B
    (Check out the Kalamazoo Model II: http://www.rru.com/~meo/Guitar/Amps/...ooM2Schem.jpeg).
    I had one of these amps for a while and the Vibrato seemed to change the distortion more than the volume.
    Any ideas how to work this one out?!
    Hope everyone's been doing good!
  29. #99
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Long overdue for an update on things...
    First up, here's a quick recording I did yesterday trying the amp out. No FX at all, just two mics straight into the soundcard; only balanced the L/R volume a bit.
    The first few riffs are SM7 and SM58 on the grill; last riff was two SDC mics a few inches from the grill.
    https://soundcloud.com/user-34254870...ono-amp-test-1
    Couldn't be happier with the sound, very punchy, nice clean sounds, breaks up pretty well. I didn't crank it all the way as I need to replace some long wires with some short shielded cable or it will start ice-picking your ear.
    In the photos you can see the new faceplate. After leaving it out in the elements all winter then giving it an acid bath it turned out nice and beaten looking. Then drilled it out and got a local metal shop to bend the sides for me. Going to color the metal with heat.
    I got the delay working, and I went ahead and built an external tremolo. It's a little more square wave than sine wave but its cool enough.
    I want to coat the faceplate with polyurethane, but still have to figure out the right solution for labeling all the controls.
    Would love to hear suggestions!!
    And now some photos:
    The new faceplate - here i've installed all the controls for the amp stuff. Those controls are (for both left and right channels):
    Negative feedback; Lift tone-stack; mid-cut; mid-boost with potentiometer control, cathode bypass cap, 100pf bright cap, volume controls.
    All the other holes are for effects, the mixer and some multipliers. 85% done on all those other circuits.
    The close-mic arrangement with SM7 and SM58 -
    The effect circuits that will be going inside -
    3 Not allowed! Not allowed!
  30. #100
    May 2007
    pacific north west
    15,338
    Received: 2,316/4
    Given: 2,693/0
    30
    That's a great, and useful tone. More of a balanced clipping on LF and HF like good tones for blues, country and some rock and hard rock. I think I can tell it's a pretty nice sounding guitar you have plugged into it too. My own "tone" is definitely more clipping in the upper mids for definition under heavier clipping. But there's been many times I considered making adjustments so my own amp could do what yours is doing
    Nice.
  31. #101
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Hiya Chuck!
    Thanks a lot for the awesome feedback.
    I am stoked to hear you say that, and stoked with this amp. The first three riffs on that recording were all the same mic'ing and settings - the differences were only due to how hard i hit the strings; so it sure does seem pretty versatile. Once i get those shielded cables installed i should be able to crank up the mid-range. I do also still have the bass/treble controls from the original amp in the circuit (optional!) so i can try to go for that mid-range tone better in the future.
    And I have you to thank - all the changes to the circuit were your suggestions, so your own amp is in very good hands should you decide to mod it! ;-) But i'm here for you if you need any complex/improbable solutions for any simple problems you might have... heh hehhhhh.
    Cheers and thanks again!!!!
    -Steve
    PS: would love to hear anyone's suggestions for labeling. at this point i'm looking at black ink on transparent paper, then polyurethane coating.
  32. #102
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Oh and by the way - the amp gets the credit and not the guitar - it's a knock-off strat i got for 25 euro that is literally called a "Fire Legend"! I am the king of crappy gear; probably why i love DIY so much - because it allows us poor folk to rise above!
    2 Not allowed! Not allowed!
  33. #103
    May 2007
    pacific north west
    15,338
    Received: 2,316/4
    Given: 2,693/0
    30
    Oh, I didn't say "nice guitar". I said "nice sounding guitar". My history is peppered with budget instruments that just felt and sounded "right" so I'd buy them if I was in the market.
    And I wouldn't change a thing about the basic circuit yo have since it's sounding good now. Trust me, it's easy to get lost a few mods down the road and lose your way back. Your ear memory starts to get fuzzy and you're never again sure if you should have left well enough alone. You could ADD circuits though. Like switchable caps and resistors to reshape EQ for heavier clipped tones, etc.
    You mentioned needing to add shielded cables to crank it. Is the amp unstable at higher gain settings?
  34. #104
    Dec 2011
    136
    Received: 7/0
    Given: 1/0
    8
    Hey Chuck,
    Yeah, i must admit that crappy guitar does sound good. I have another strat-copy that's by Samick and it's really dark, but that makes it sort of unique. Different is good.
    I am open to adding circuits that could get the gain higher, but i do have to fix this squealing first. I am guessing its from non-shielded cables on some of these controls. I wired everything long at first but now I have the faceplate done i can re-do those cables to be short (and shielded).
    I did put the 100pf bright cap on a switch, but didn't hear any difference. I'll double check i didn't wire (the simplest of all the mods) wrong.
    yeah, when i lift the tone stack, or go for the mid-range control setting on high it does start to squeal.
  35. #105
    May 2007
    pacific north west
    15,338
    Received: 2,316/4
    Given: 2,693/0
    30
    Since the unit wasn't initially designed to be stable as a guitar amp the layout may be less than ideal for stability at higher gain. The location of tubes, transformers, terminal strips, etc. could have you running leads in less than ideal paths. A couple of clear gut shot pics might allow for a forum member to ID changes in wire routing that might help with the stability issue.
  1. Peavey Stereo Chorus 400 footswitch circuit needed.
    By redneckgeek in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-12-2017, 01:06 AM
  2. early 60's 6g2 brown Princeton circuit
    By mort in forum Debugging Your Build
    Last Post: 04-03-2016, 09:27 PM
  3. Early 60's Ampeg Reverberocket: need help with noise
    By Jonny toetags in forum Maintenance, Troubleshooting & Repair
    Last Post: 03-05-2014, 07:08 PM
  4. Help identifying early 60's strat
    By jez in forum Pickup Makers
    Last Post: 02-09-2014, 08:36 PM
  5. Mod'ing organ amp for guitar:
    By Rafael in forum Conversion Projects
    Last Post: 05-13-2008, 04:53 PM
