This is a question for those of you cut your nut slots. Do you follow the headstock angle or do you file parallel with the fingerboard? The nut does several jobs, 0-fret, string spreader/keeper Headstocks are angled to exert pressure on the string to keep the string from popping out of the slot. Does it make a difference? Wont the angled slot wear faster due to the peak or edge fret side? Does it affect playability? Thanks
Nut slots-angled or straight?
The nut slot needs to slope upwards towards the fretboard so that there is a sharp enough break angle for a solid tone. A completely level nut slot could have a buzzing banjo or sitar effect. (I learned that from Wayne "Doc" Horner here at AMPAGE in the late 90's.)
Steve AholaThe Blue Guitar
www.blueguitar.org
Some recordings:
+1.
The strings angle upward towards the bridge, so a slot that's level with the fingerboard would buzz on open strings even if it didn't on fretted notes.
There's another factor; strings have a certain bend radius - particularly heavier, wound strings where they can get coil-bound and in any case have a stiffer core. This means that when a string is bent over an edge it can rise slightly immediately after the bend. That is to say, it doesn't have the same bend radius as the edge it's bent over (unless it's forced to do so).
Angling the slot addresses both of these and results in buzz-free nuts.
I guess there would be increased wear compared to a level slot, but a guitar with a buzz at the nut is no good.
On a related note (C#!) there has been a big problem with recent low-end models Gibson having nuts which grab on to the strings causing them to go flat even after pre-stretching the strings. One test for this is to tune the string to pitch then push down on the string between the nut and the tuning key. If the string goes sharp and doesn't return to pitch you have the dreaded Gibson grabby nut syndrome.
To save wear and tear on my nut files I've been using a set of oxy-acetylene tip cleaners to make the nut slots a little wider. Home Depot sells a set of 13 for $3.90.
Lincoln Electric Long Tip Cleaner-KH574 - The Home Depot
Or if money is no object you can buy a set of 6 "nut slot saw rods" from an ebay seller for $15.99 incl s/h
Vintage 1950's Carnaval púrpura de cristal de palo de vela los titulares de las uvas y hojas Set | eBay
I've been handing out the $3.90 sets to my luthier friends as a little thank you present for all of the advice that they have given me...
www.blueguitar.org
Some recordings:
I guess there would be increased wear compared to a level slot, but a guitar with a buzz at the nut is no good.Don't believe everything you think. Beware of Rottweiler. Search engines are free.
I wanted to add--stiffness increases with core diameter as Mick described above, and that effectively shortens the vibrating length of the string. Which is why we need to compensate for intonation!Don't believe everything you think. Beware of Rottweiler. Search engines are free.
Originally posted by Steve A. View PostOn a related note (C#!) there has been a big problem with recent low-end models Gibson having nuts which grab on to the strings causing them to go flat even after pre-stretching the strings. One test for this is to tune the string to pitch then push down on the string between the nut and the tuning key. If the string goes sharp and doesn't return to pitch you have the dreaded Gibson grabby nut syndrome.
Steve Ahola
Another tip: If you end up cutting a nut slot too deep before replacing the nut try filling the slot in with Superglue and baking soda, and then recut it. Back in the OLDE days I'd cut a small piece from a string envelope and wedge it under the string...
www.blueguitar.org
Some recordings:
