Very low output Ashdown Evo II 300 bass amplifier
  • Very low output Ashdown Evo II 300 bass amplifier
    Hi Folks,
    Im trying to find out whats going on with the ashdown in the title, it has a really low output volume and the Input Meter doesnt read anything when injecting a signal, or playing trough it.
    I have checked so far the power transistors:
    Tested TR21,TR19,TR13
    TR7,TR6,TR4
    TR22 AND TR1 are not in the board, I guess they are for the 500W version of it.
    they tested fine.
    I have also checked voltages of the preamp magnifier module.
    +15/-15 voltages points in the schematic seems correct, also checked the voltages at the ecc83 valve, which are +360V.
    I think the issue resides at the preamp but cant locate where.
    I have plugged the amp and read the AC over the speaker output and the peak of it is about a volt when cranked on a 8Ohm load, which is really really low.
    Any points for this one please?
    Thanks a lot in advance!
    Preamp schematic and power amp attached.ashdown evo300 preamp.pdfClick image for larger version
Name:	ashdown evo300 power amp.png
ID:	871108ashdown evo300 preamp.pdfClick image for larger version
    ashdown evo300 power amp.pdf
    Have you tested the loop jacks?
    Divide and conquer, take the signal from the preamp output jack and feed it to another amp. Do you get a good signal there?
    Inject a signal into the power amp in jack. Do you get a good signal from the speaker?
      If the INPUT meter doesn't move, that is a clue the INPUT area is the issue, not the power amp. SO look at the input stage and the first op amp or two.
        Thanks a lot! will try and report back!, Enzo thats what I tought, as the meter is not moving issue must be on that stage, but voltages look good in there.... will try pumping in and out of the effects loop!
          VOltages are only part of the story - just because the battery has a charge doesn't mean the car will start. A dead JFET or dead op amp will kill your signal, even if they have voltage.
          Apply a signal to the input and trace it through the amp - where does it stop?
            First thing I would suspect is a PCB mounted input jack. Like Enzo says. Shove some signal into it and trace it.
