Results 1 to 33 of 33
Thread: Transformer wire layout help
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,173
    Received: 50/1
    Given: 49/0
    13
    I'm planning on building a marshall style 50 watt amp ,hopefully using 2 5881's or 2 el34 & 3 preamp tubes
    I have this 40 watt Ashdown peacemaker 40 that i would really like to use the trannys from .as this build would not be in the budget without the freebe trannys
    So to get things rolling these trannys powered 4 el84's & 4 12ax7's
    I need some help with the pinout of both the power & output trannys
    Void the yellow arrow /circle ,it's from a previous thread.
    Power transformer
    red & red = heaters 6.3vac
    Blue=
    Blue=
    yellow=
    black=
    yellow=
    I noticed the blue goes to some big electrolytic's maybe the B+
    Yellow goes to diodes..... Rectifier ?
    & black could be a ground
    OUTPUT tranny
    I may have figured out but not 100% about the last 4
    Blue=16ohm
    Yellow=8ohm
    white=4ohm
    Green= Ground or common ? is common the ground ?
    Red=center tap
    Black = Anode
    Brown=Anode 2 ..Please feel free to discuss this
    Near Dallas Texas
    3,576
    Received: 266/0
    Given: 133/1
    19
    The yellow-black-yellow is probably around 24 to 28 VCT. It goes to the regulators and also powers the preamp heaters with DC. The blue-blue is about 240VAC for the high Voltage. This is not center tapped so you'll need a full wave bridge to rectify it, just like the schematic. Red-red (unusual color choice) appears to be 6.3VAC for the power tube heaters. There should be enough current to power two EL34s or 6L6/5881s. I don't see anything to indicate what the PT primary might be. That might be confusing if there are multiple mains Voltage selections.
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    Here's some pics
    May 2010
    Sioux Falls, SD
    6,926
    Received: 1,693/2
    Given: 1,218/1
    18
    loudthud has the PT secondary for you. As far as the primary, just wire it like it is in the original amp. Looks like parallel windings for 110-120V operation. Looks like you already have the OT figured out.
    Edit: And yes green is ground.
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    Great I'm leaning toward building something like this so if we can apply my trannys to this layout
    & I've noticed this amp uses dc heaters as well
    Any help as Loudthud explained the yellow/Black /Yellow or (orange) goes to the regulators & the dc heaters I guess that is the small board to the far left ?
    Near Dallas Texas
    3,576
    Received: 266/0
    Given: 133/1
    19
    Quote Originally Posted by copperheadroads View Post
    No, that board is a Voltage Doubler meant to run from a 5VAC heater winding and convert it to 6VDC.
    The Ceriatone layout also uses a center tapped winding for the B+. That won't work with your transformer.
    Your transformer has about 24VAC center taped and after the regulators creates plus and minus 12.6VDC. Your transformer could be wired to make a single 12.6VDC supply if you don't need the +/- supplies for the solid state stuff.
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    Thanks for the help
    I will have to do some research on what to do with the heaters for the preamp tubes
    I guess wiring it more like a traditional JCM800 wont help me much . I wonder if there is enough amps in the 6.3v winding to supply all the tubes with AC ? like the jcm layout
    I may stick with a traditional layout as well
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    This project has taken a turn as I have ordered transformers for my marshall build so that gives me this for another future build ,Just wondering if i could use these trannys for a amp with a rectifier tube like a bassman or similar .
    Near Dallas Texas
    3,576
    Received: 266/0
    Given: 133/1
    19
    You can use a tube rectifier, but you will need two silicon diodes to complete the bridge because the transformer has no center tap on the HV winding.
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    Quote Originally Posted by loudthud View Post
    Ok... Thats works ...
    What would you do with the Yellow /black/Yellow wires tape them off ?
    Near Dallas Texas
    3,576
    Received: 266/0
    Given: 133/1
    19
    I thought you wanted to use the Yellow/black/Yellow winding for preamp DC heaters. The 6.3V might not have enough current for EL34s and four 12AX7. I forgot to mention you will need 5VAC for a rectifier tube. No 5V winding on the transformer.
    Tape is not a great idea for an unused winding. Heat shrink tubing is safer, just get the right size and shrink it tight so it won't fall off.
  12. #12
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    This is a build or 2 away but suggestions on what to build . Love to do some sort of bassman circuit with a tube rectifier but with no 5v winding on the tranny . would either a 6v rectifier tube like a 18 watt marshall ez81 has or a dc rectifier be possible
  13. #13
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    Ok getting back to this build or conversion my plans may of changed on what circuit as i'm gonna be building a 2 6l6 power section & 3 or 4 preamp section of some sort of amp with no fancy rely switching channels & possibly a single channel
    so to get the DC heater circuit started Click image for larger version.
Name:	ashdown dc heater circuit.jpg
    I'm assuming it's 15vac from the transformer i am assuming the +12.8v & -12.5v are the heaters ,PL2 would work for the 12vdc pilot light ?
    & in this schematic what is the CHI ? at the end of circuit
  14. #14
    Near Dallas Texas
    3,576
    Received: 266/0
    Given: 133/1
    19
    CHI might be a connection to the chassis.
  15. #15
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    Ok Great so i guess I'm on the right track
  16. #16
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    I created a small board layout for the regulator for the DC preamp heaters
Name:	Ashdown dc heater board crop.png
  17. #17
    Near Dallas Texas
    3,576
    Received: 266/0
    Given: 133/1
    19
    Check the data sheets on the pin-out of the three terminal regulators. The positive and negative versions do not have the same pin-out. They will need some kind of heat sink. This needs to be part of the layout.
    Check the size of the electrolytic caps you intend to use. They will likely be much larger than your layout shows.
  18. #18
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    I was hoping on using the stock ic 7912 v& the 7812 along with the heat sinks ...i did have trouble sourcing them as an alternative in case the original's failed .
    According the the schematic no cap values no more than 25v .. I will run through the physical board itself . & let you know
  19. #19
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    Using this amp as the basis ,I've decided to attempt to build a TrainWreck express using 2 5881 tubes for the power section & the DC heater circuit .
    My Question is about the full wave bridge as i have no center tap, In the Ashdown schematic ,I see there some small caps & a 220k resistor before the filter caps ,I guess this is necessary part of the Full wave bridge ?
    Here's the layout & schematic Click image for larger version.
ID:	45332 Click image for larger version.
Name:	TwreckKelly Revised.JPG
ID:	45333 & the Ash down schematic Click image for larger version.
Name:	ASHDOWN full wave bridge.jpg
  20. #20
    Feb 2010
    12,638
    Received: 2,186/24
    Given: 5,505/11
    24
    Consider the 220K as a bleeder resistor (for first cap) and the 4n7 caps as noise suppression for the diodes.
    Neither are necessities or really part of a bridge, but both are useful additions.
  21. #21
    Near Dallas Texas
    3,576
    Received: 266/0
    Given: 133/1
    19
    It is unclear which 220K you are talking about. There is one that is part of the bias Voltage generator. That bias Voltage circuit won't work when a full wave bridge rectifier is used.
  22. #22
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    looks like R87 maybe just before (left) of the first 47uf filter cap
  23. #23
    Feb 2010
    12,638
    Received: 2,186/24
    Given: 5,505/11
    24
    Yes, R87 is just a bleeder for the cap. But take note of what loudthud said, the bias circuit will not work with a bridge, you will have to find a different source for bias voltage. How does the Ashdown in your example do it?
  24. #24
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    what would we need to do ?
  25. #25
    Near Dallas Texas
    3,576
    Received: 266/0
    Given: 133/1
    19
    Basically, you need a capacitor instead of the 220K. Here is an example, bias circuit is on page 2: http://el34world.com/charts/Schemati...0-02-iss14.pdf
  26. #26
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    Sorry I'm not seeing it in the schematic ,,I will do some more research .
  27. #27
    Feb 2010
    12,638
    Received: 2,186/24
    Given: 5,505/11
    24
    Look at the D5 sector of the schematic (pg2). Cap is C12. WH point comes off the power transformer.
  28. #28
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    Thanks I did look at that
    Wouldn't this be a similar schematic Click image for larger version.
Name:	cap_coupled_bias_supply2 - Copy.jpg
    At the bottom of the page
    Capacitor Cupled Bias Supply
    http://www.valvewizard.co.uk/bias.html
  29. #29
    Feb 2010
    12,638
    Received: 2,186/24
    Given: 5,505/11
    24
    Yes, very similar. That will get you a bias supply without a CT in your HV winding.
  30. #30
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    Here's the Chassis , Click image for larger version.
ID:	45380Click image for larger version.
    My plan was to to cover larger holes that are towards the center & install my turret or eyelet board in that area & possibly drill holes (atleast one new hole ) for the power tubes , but I am not liking how close V1 will be to the Output transformer this build will have dc heaters on the preamp tubes . I wonder would if it be better if i move the OT up next to the power transformer , this is a combo amp but i think there is enough room to move the OT next to the PT .let me know what you guys think ?
  31. #31
    Sep 2011
    Pace, FL
    3,636
    Received: 1,320/102
    Given: 183/36
    12
    They have things to pop into unused holes. I'll post some pics tomorrow in this thread.
    nosaj
  32. #32
    Sep 2011
    Pace, FL
    3,636
    Received: 1,320/102
    Given: 183/36
    12
    Quote Originally Posted by nosaj View Post
    nosaj
    Got them from a radio shop closeout.
    They just pop in.
    nosajClick image for larger version.
ID:	45400Click image for larger version.
ID:	45399Click image for larger version.
  33. #33
    Jun 2009
    2,173
    Received: 50/1
    Given: 49/0
    13
    Getting some of the components ready to order over the weekend ,I was thinking of possibly drilling new holes for the 5881's & using the back holes for the preamp tubes/sockets .covering over the center sockets with some sort of alloy plate .
  1. Quick transformer layout question
    By mort in forum Build Your Amp
    Last Post: 02-27-2014, 08:24 AM
  2. Fender reverb driver transformer - green wire grounded?
    By RC99 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-05-2013, 12:51 AM
  3. transformer orange wire
    By pbiagi in forum Tweed Builders
    Last Post: 02-09-2013, 07:27 PM
  4. Replies: 6
    Last Post: 03-14-2011, 01:19 PM
  5. Transformer wire colour? red/yellow
    By ValveBytes in forum Music Electronics
    Last Post: 11-02-2007, 12:35 AM
