What is going on here with V3B? It looks almost like a Cathode Follower, but not quite. I never seen this before.
Hiwatts..
Originally posted by leadfootdriver View PostWhat is going on here with V3B? It looks almost like a Cathode Follower, but not quite. I never seen this before.
*also, a grounded grid stage would have to be driving from a low impedance source, and these are NOT low impedance signals,
Edit: I read the schematic wrong here. See beliw.Last edited by SoulFetish; 12-13-2016, 10:06 PM.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
One way to look at it is that the CF triode is providing a ‘regulated’ DC voltage level to bias the LTP. But the 100k resistor to grid 1 of the LTP (compared to the 1M on the other grid) means that there is influence on the AC signal, as SoulFetish suggests. The low impedance at the cathode of the CF would make it harder to overdrive the LTP.
So, might this be a part of the "Loud & Clean" reputation they have?
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
http://music-electronics-forum.com/t39917/
I asked this question last year. Lots of good info up there and it was speculated that you could achieve the same thing using a potential divider from the B+ rail.
Originally posted by Zozobra View Posthttp://music-electronics-forum.com/t39917/
I asked this question last year. Lots of good info up there and it was speculated that you could achieve the same thing using a potential divider from the B+ rail.If it still won't get loud enough, it's probably broken. - Steve Conner
Notice that it has low current through it. While it is within its linear range it steals drive from the PI by loading the previous stage, as a result of its low output impedance. But as the drive increases it saturates in one direction, and turns off in the other. In either of those states it no longer has a low impedance; this effectively increases the gain of the stage driving the PI, since it is no longer loaded down. It might compensate for a non linear response in the output stage.
I was thinking about it for a moment after I posted. And these guys are right. Normally you would take advantage of an opportunity to bootstrap and bias this type of phase inverter for a very high impedance. This way definitely loads down the previous stageIf I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Thanks for the replies. So, it's a fixed bias LTP... Very clever. Fryette uses an AT7 forma PI Driver of sorts in a Deliverance 120, but I haven't seen a schematic. Fryette amps are referred to as Hiwatt like.Last edited by leadfootdriver; 12-13-2016, 09:45 PM.
Originally posted by Mike Sulzer View Post... as the drive increases it saturates in one direction, and turns off in the other. In either of those states it no longer has a low impedance; this effectively increases the gain of the stage driving the PI, since it is no longer loaded down. ...Last edited by Malcolm Irving; 12-13-2016, 07:53 PM.
Originally posted by Malcolm Irving View PostI like the idea of this, but I don't think the previous stage could provide enough output voltage swing to get the CF out of its linear range. The resistance to ground seen at the cathode of the CF is only about 620 ohms. Combining that in a potential divider with the 100k resistor (going to grid 1 of the LTP PI) means that an output swing of 162V from the driving stage would be needed to move the cathode voltage of the CF by just 1V.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by Malcolm Irving View Post...means that an output swing of 162V from the driving stage would be needed to move the cathode voltage of the CF by just 1V.If it still won't get loud enough, it's probably broken. - Steve Conner
Oh, i realze now i totally saw connections that were not there. It's amazing to watch a circuit change completely in your mind after you move a few connection to where they need to be. Thats what I get for posting at 3 o'clock in the morning when I'm exhausted. I had time to take a second look, And I realize I read this wrong. (I friggin' always do that!) Anyway, the active tone control doesnt connect at that point on cathode with the grid leaks. This isnt a mixer at all. It does look like a bias circuit for the most part with active balancing component (I think)... That sucks though, what I thought was happening seem more interesting though.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by eschertron View PostSo an argument in favor of voltage stability? ...
Why have AC coupling into the PI, but a fixed bias scheme (instead of cathode bias) on the PI?
