Results 1 to 22 of 22
Thread: Another mystery amp
    Junior Member
    Apr 2016
    Durban South Africa
    12
    Another mystery amp
    Hi Guys,
    New to this forum. I have posted this on other forums, searched the Net etc... No luck!! Please can someone try and identify this amp in the hope of obtaining a schematic. 1x12 combo. 2x 12AX7's, 2x 6v6 and 1x EZ81.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,632
    Received: 559/1
    I have no idea who made it, but it is a simple amp, four tubes. I don't count the rectifier, we all know what it does. A push pull output, we know what that ought to look like. Two channels. One of the tubes is the phase inverter. SO I bet if you sit down with a pad of paper and a pencil, you could draw up a schematic from the circuits in half an hour tops. If you are familiar with the circuits, and don't have to look up the tube pins, hell, 10-15 minutes.
    I don't know where you are - really ought to include at least your nation on the profile - but since the power switch is labelled "mains" I assume this amp is not from the USA.
    Junior Member
    Apr 2016
    Durban South Africa
    12
    Thanks for the reply,
    1. I will update my profile. Sorry this was my first post. I reside in South Africa. Also I am new to this addictive hobby and have no electronic background.
    2. I will attempt to draw this circuit. Will be a good exercise. Don't feel too confident drawing it,,, but hey.. I have to learn.
    3. I doubt this is a push pull amp. I'm thinking it is a PSE, 5 or 10w (although the OT is small for SE!). Also, this amp has a shitload of gain (hardly any cleans to speak of....even with single coils). So... Surely all this gain can't come from 1/2 a tube? Huge controlled feedback (would make a great rock recording amp).
    Will keep you posted
    Old Timer
    Chill-Ville, VA
    2,592
    Received: 132/1
    Given: 270/6
    I don't want to be presumptuous, but you COULD have 1/2 AX7 each as a first gain stage per channel, then a second shared gain stage, then the tone stack, then a third shared gain stage right before a simple Cathodyne phase inverter, driving two Push-Pull 6V6s... main point, you could potentially get three gain stages out of it... since you actually have FOUR triodes to play with. But we'll know once you can draw it out.
    Justin
    30,632
    Received: 559/1
    It is conceivable the two 6V6s are in parallel and thus single ended, but far more likely to be a push pull pair.
    Pull up a schematic for an old Fender Deluxe, like the 5E3 or 5D3. I bet your circuit looks very similar.
    Junior Member
    Apr 2016
    Durban South Africa
    12
    Thanks guys,
    The reason I suspect PSE, is because of the perceived power output. I have a 1961 vintage Epiphone (25w), which is WAY louder!! Will be great if I have a basic 5E3 circuit here. That was going to be my next build. So this would be a good donor chassis. The amp voicing is definitely NOT a Fender type voice, so will redo the tone stack. Actually, once I have checked the voltages, I will determine weather this is worth stripping or just modding.
    30,632
    Received: 559/1
    Loudness isn't a good indicator of power. Doubling or halving power is only a 3db change. Speaker efficiency can have just as large an effect.
    Easy enough to determine. Are the two tube sockets wired in parallel or not? Are there three primary wires or two on the OT?
    Junior Member
    Apr 2016
    Durban South Africa
    12
    I will try get in there this weekend and revert. Thanks for the input guys.
    Junior Member
    Apr 2016
    Durban South Africa
    12
    As promised, here is the schematic. There are probably errors.. But you get the idea. I do believe it has a STRANGE tone stack arrangement with the 2 volume controls (instrument and microphone).
    Feb 2010
    10,189
    Received: 331/1
    Given: 652/0
    Have never come across a phase inverter like that before, but I think the 22n feeding the lower 6V6 should come off the PI plate, not the grid.
    Junior Member
    Apr 2016
    Durban South Africa
    12
    You are correct. My mistake, the 22n is supposed to come off the the plate of the v2b, which is feeding to the "inverted" 6v6. See updated schematic. Yes, the phase inverter is strange, but I wouldn't know...I am new to this game.. Also, weird tonestack (I think).
    Would a bypass cap on the common cathode resistor increase power output?
  12. #12
    Feb 2010
    10,189
    Received: 331/1
    Given: 652/0
    A bypass cap for the output tube cathodes won't increase power output, just gain.
    So it will get to full power at a lower setting on the volume control.
    Power output is pretty much set by the capability of the power supply (power transformer).
  13. #13
    Jun 2011
    Pittsburgh PA
    93
    Received: 2/0
    Given: 4/0
    That phase inverter is called a "paraphase". It takes advantage of the fact that a standard common cathode stage inverts the signal, and uses the signal driving one of the power tubes as the input to another triode which creates the inverted signal for the other power tube. It looks like it's using negative feedback to control the gain so that both sides see roughly equal drive, but I bet it's not actually all that equal which is probably a factor in why, as you say, the amp sounds like it has a shitload of gain.
  14. #14
    Old Timer
    Chill-Ville, VA
    2,592
    Received: 132/1
    Given: 270/6
    It doesn't look like the "normal" way I've seen a Paraphase drawn, but I know that in either RDH3 or RDH4, there are a good 6 or 7 ways of phase splitting or inverting that are not seen commonly in guitar amps. I guess these days, there are only 2 in heavy use - Cathodyne & Schmidtt (LTPI)? Given the pros and cons listed for each, some of those unused ones sound like they might be worth considering in guitar amps. Fidelity? We don't need no stinkin' fidelity! So I shouldn't be surprised that a Mystery Amp has a Mystery PI.
    Justin
    To clarify: why it didn't look like a Paraphase to me is because it looks as though the full amplified signal of the first stage is passed straight to the grid of the inverting tube, without the usual voltage divider to knock the incoming inverting signal to the same level as the incoming non-inverting signal... weird, for sure!
  15. #15
    Dec 2009
    Devon, UK
    2,898
    Received: 149/0
    Given: 124/0
    I believe the feedback should go to the cathode of the first triode that forms the driver stage pair.
  16. #16
    Junior Member
    Apr 2016
    Durban South Africa
    12
    Angry
    Quote Originally Posted by Justin Thomas View Post
    Justin
    There is a possibility I have drawn it wrong. I will check
  17. #17
    30,632
    Received: 559/1
    I wouldn't worry so much whether it looks "correct" for a certain type PI, but rather will the circuit work. Ther may be better ways or a "proper" paraphase might be different, but they could have purposely or ignorantly have designed it different. But it needs to drive one power tube with a signal and the other with its invert. SO we need to see if it will.
  18. #18
    Junior Member
    Apr 2016
    Durban South Africa
    12
    Hi Enzo,
    This circuit actually was a working amp. The cabinet was cheaply made, so I didn't expect much. Very distorted and no 'balls" with no sparkle/chime. Could very well have been "ignorantly designed". The HT is a low 290v. What do you guys suggest I change to temporarily improve matters. I will eventually use this chassis to build a 5e3 design. I already have OT and MULLARD OS 5y3 recto lying in waiting. Need to get a PT (325/325) in the new year.
  19. #19
    Junior Member
    Apr 2016
    Durban South Africa
    12
    OK.. Have finally got a PT (unfortunately it's a toroid), but it will do. Stripped chassis and done a temporary board for 5E3.
  20. #20
    Dec 2011
    Pretoria, South Africa
    678
    Received: 1/0
    How did the amp repair come along? All good and grafting?
  21. #21
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    2,669
    Received: 44/0
    From the tube complement he listed earlier it looked like an 18 watt Marshall setup except with 6V6s instead of EL84s and kind of a low B+. I would have put in an SS rectifier and made a Spitfire or something similar out of it.
  22. #22
    Junior Member
    Apr 2016
    Durban South Africa
    12
    Hi Guys,
    Been a while. I eventually built a 5E3 type amp into the cab. Was a quick rebuild on existing board. Amp worked, but was noisy. I have since built up a new turret board, so will revisit this project and post. I am thinking of a Tweddle Dee type 5E3. Thank you for all the help.
  1. Mystery Japanese amp
    By Wakculloch in forum Vintage Amps
    Last Post: 06-10-2016, 08:49 AM
  2. mystery lead in Peavey amp?
    By tedmich in forum Theory & Design
    Last Post: 05-20-2014, 03:47 PM
  3. Mystery Amp - Take a look and see if you can help
    By Csquare4 in forum Conversion Projects
    Last Post: 07-21-2011, 10:31 PM
  4. mystery amp
    By roughcut studios in forum Vintage Amps
    Last Post: 11-19-2010, 09:12 PM
  5. Mystery Caps in my amp??? need help
    By lustandfury in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-30-2008, 04:55 PM
