I believe this is from 1998. It came in with transistors different from those listed on the schematic. Not on any of the schems I've seen. It had 2SC2837 outputs. Anywho, one had shorted. I replaced both outputs with a bit beefier transistor - 2SC5242. NPN and same pin out, slightly higher rating.
Now, I'm mounting them to the heatsink, but there are no insulators! I checked the old transistors and the heatsink etc... there are NO insulators in here. This heatsink is mounted directly to the chassis. Looking at the schem this seems very odd and crazy to me that this amp was working at all previously. It WAS working when it came in but customer said the power would go in and out. I didn't believe him as I ran the thing for hours on 11 and had no issues. Finally I jiggled the ext. spkr jack while it was running and it blew the fuse, and shorted one of the outputs. So I assumed one of the outputs was the issue and had been on its last leg and causing the issues for the customer.
Now I'm wondering how it was working at all with the collectors of the outputs shorted to ground via the heatsink. This DOES NEED INSULATORS correct? Just want to be sure - I can't see how I could be wrong - but safer to ask you all.
thanks
http://music-electronics-forum.com/a...-blonde-00.pdf
thanks
