When i start to wind a coil i can get to around 200 wounds and it will still read a resistance of about .2 kohms but if i begin to wind any farther than that the coil won't read anymore. I completely unwound the pickup and there were no breaks at all. i have absolutely no clue what is going on. any help????
43 AWG problem
that is what's odd though is that it will be the very first time i test the coil so when i unwind it, i just go ahead and discard that wire and start with something fresh. could it be that i am putting too much tension on the wire when i'm winding it?
too tight....
Weird, I posted this before and it disappeared. Yes you are winding too tight, especially if its plain enamel which shorts out real easy with tight winds. You want to wind so you're not stretching the wire, you don't need much tension with the thinner guages....http://www.SDpickups.com
Stephens Design Pickups
Originally posted by Possum View PostWeird, I posted this before and it disappeared.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Dave...
Well Dave it happened again, I just read your post and it vanished while I was reading it. Your photo is starting to fade, ok time travelers your game is up, they're taking you back home.......hope this gets posted....http://www.SDpickups.com
lol, I've had complete posts disappear too. So, I usually do a select all and copy prior to submitting.int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
www.ozbassforum.com
Originally posted by lordnikon View PostWhen i start to wind a coil i can get to around 200 wounds and it will still read a resistance of about .2 kohms but if i begin to wind any farther than that the coil won't read anymore. I completely unwound the pickup and there were no breaks at all. i have absolutely no clue what is going on. any help????sigpic Dyed in the wool
shitty wire....
Man this REA 43 PE is shit, any tension at all and the coils go DEAD. Just like good old Korean crap....http://www.SDpickups.com
Its current issue, REA is the only PE maker in the US and their stuff is mediocre.....http://www.SDpickups.com
I'll ask if anyone has had similar problems, I also think I heard they aren't selling 43 PE anymore too. There's no other choices, poly wire is all thats left. MWS basically sells wire, they don't cherry pickup no matter how much wire you buy, and REA is the only PE maker left in the US. They would only ship me another of the same..http://www.SDpickups.com
