Results 1 to 7 of 7
Thread: help!, i owne a carvin mts 3200
    New Member
    Dec 2016
    5
    0
    I bought a carvin mts3200 head and it came with 3 el34 and 1 6l6 mesaboogie in the socket v9-6l6gc, I did not realize that when I bought it, I have it in 50w mode, where I live turned out to be complicated to get tubes, and the importation It will take longer than I thought, since I used the head to volume less than 1 and I do not notice anything strange and I bought the head the only thing I want to do is to use it but, what can happen if I continue using the head until I get import valves A new set? thx for future help to all who love music, play it and resolve our questions and gear troubles
    May 2010
    Sioux Falls, SD
    6,934
    Received: 1,695/2
    Given: 1,220/1
    18
    In half power mode, V6 & V9 aren't doing anything anyway so it won't matter what tubes are in those sockets or if there are even tubes in those sockets at all. If you don't plan to use it in full power mode, you don't even need to bother with ordering tube(s), unless there's some other problem with the tubes. Here's a schematic if you care to see how it works. When you switch the amp to half power, the cathodes of V6 & V9 are removed from ground so they do not conduct.
    http://www.carvinmuseum.com/pdf/amps/MTS3200REV-E.pdf
    P.S. Welcome to the place!
    New Member
    Dec 2016
    5
    0
    thank u very much, i feel happy now , this forum its the best
    Nov 2006
    Sacramento, CA
    503
    14
    Where should the tube switch be set? Don't 6L6's need more bias voltage?
    May 2010
    Sioux Falls, SD
    6,934
    Received: 1,695/2
    Given: 1,220/1
    18
    The single 6L6 is in a socket that is not working in half power mode. As I read it, the rest of the tubes are EL34's, so the switch should be set for EL34.
    New Member
    Dec 2016
    5
    0
    Yes, it is set for el34 bias
    Senior Member mozwell's Avatar
    Sep 2009
    Australia
    650
    Received: 15/0
    11
    personally, i would remove the tubes in V6 and V9, especially as if you ever put it in full power mode (even by accident) the 6L6 will be in circuit, and we don't want that causing any damage to the tube or output transformer (due to 1x EL34 and 1x 6L6 in parallel)
    I don't know enough about the bias of these two tubes to say if it will cause damage, but better to be safe
    Also, the PT wont have to supply heater current for V6 and V9 so it will run a little cooler
  1. Carvin MTS 3200/3212 Combo tube amp
    By JKW in forum Music Electronics
    Last Post: 04-12-2016, 04:34 PM
  2. Carvin MTS 3200/3212 Combo tube amp
    By JKW in forum Guitar Amps
    Last Post: 03-24-2016, 07:59 AM
  3. Carvin MTS 3200 Master Tube Series - Reverb and other ?s
    By misterc57 in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-04-2010, 10:22 PM
  4. Will a pair of 6L6's take 3200 ohm load push pull?
    By priesty in forum Theory & Design
    Last Post: 08-03-2010, 03:14 PM
  5. Randall MTS series (New Guy)
    By SacredGroove in forum Mods & Tweaks
    Last Post: 04-01-2010, 07:26 AM
Tags for this Thread
