Fender G DEC Junior Chassis Removal?
  • Fender G DEC Junior Chassis Removal?
    Trying to get the chassis out of the cabinet. The back panel is off and the two top mounted screws (left and right of the control panel) are removed.
    Its not budging. Is there something else holding it in, possibly the handle screws?
    Thank you
    Well, it would be a lot faster to remove the handle screws and find out, than to post here and wait for an answer. Loosen them a couple turns and see if the chassis can wiggle.
    Look inside with the back off, do you see handle screws poking through the chassis?
      I know.... and sure enough the handle screws also hold the chassis in place.
      Thank you
        Roland has a unit shaped like that.
        You need a paint scraper to break the glue loose around the chassis.
