Sometimes when I'm cruising eBay, I see an amp head for sale, and the seller says "Turned it on and the tubes lit up; did no further testing". I wince every time I see that. Will turning on an amp without it being plugged into a speaker definitely damage a transformer, or is it just more likely than not?
Turn on an amp w/o a speaker connected?
Originally posted by bluzmn View Post...Will turning on an amp without it being plugged into a speaker definitely damage a transformer, or is it just more likely than not?
What he said^^^^^^^^^^^^^^^^^^^^^^^^^
I laughed reading it too. "Amp is on.?. Guitar is plugged in.?. Huh.?." Turning it up, and uP, and UP! Blangin' on the guitar.
I turn on my amps all the time with nothing plugged in so the tubes can warm up while I get bench gear and stuff set up. They're usually in standby but I've done it with non standby amps too and never gave it another thought. Yes, there IS current and a necessary load at idle, technically. But the OT should be able to handle that level of current just about indefinitely. Way more critical when conducting signal."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostWhat he said^^^^^^^^^^^^^^^^^^^^^^^^^
I laughed reading it too. "Amp is on.?. Guitar is plugged in.?. Huh.?." Turning it up, and uP, and UP! Blangin' on the guitar.Experience is something you get, just after you really needed it.
Originally posted by bluzmn View PostSometimes when I'm cruising eBay, I see an amp head for sale, and the seller says "Turned it on and the tubes lit up; did no further testing". I wince every time I see that. Will turning on an amp without it being plugged into a speaker definitely damage a transformer, or is it just more likely than not?
Or flyback diodes on the OT, or a resistor across the output socket to damp oscillation.
One of my regular income streams is repairs/restoration of amps bought off E-bay. They often have a lot wrong with them, but only infrequently have failed OTs, unless it's a Marshall 20/20, or Laney VC30.
