Results 1 to 7 of 7
Thread: Soldering magnet wire to pad on a PCB
    Senior Member Chris Turner's Avatar
    Nov 2009
    Tucson, AZ
    240
    I was wondering if anyone had any experience with soldering magnet wire from a coil to a pad on a PCB?
    If so, what's the best way of doing so? Can you simply run the wire through the pad hole, make a solder connection on the pad, and call it a day? Or should the connection be reinforced somehow (like we do by wrapping the wire a few times around a flatwork/eyelet connection)? Or is there a nice surface mount connector that can be used?
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,664
    Received: 588/1
    Clean the enamel off the wire end so it will take solder.
    Nov 2009
    Tucson, AZ
    240
    Thanks, Enzo... I know to do this. I was more curious to know if folks thought it might be necessary to reinforce the connection somehow.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,291
    Received: 354/5
    Given: 356/5
    Itīs not a *soldering* or electrical connection prblem per se,but whether said wire willflex near the connection or not.
    Ifitdoes, itwill soon crack and split at the flexing point.
    What the solid copper wire is covered with is irrelevant, it may be transformer enamel , plastic or cloth , tinned or naked, itīs the same *mechanically*.
    Nov 2009
    Tucson, AZ
    240
    Yeah, I think by leaving a bit of slack in the magnet wire between the coil and the pad, I should be good.
    Supporting Member
    PDX
    3,221
    Received: 5/0
    Given: 5/0
    A lot of the Bartolini pickups are constructed in this way with separate coils for each string. The wire looks like 44AWG or smaller and the pads/connections seem too small to have been hand soldered. The wires always have a bit of slack. I'd love to see their production equipment.
    May 2010
    Valkeala Finland
    177
    I leave a bit of slack to the wire and wax pot the pickup after soldering all the wires to the board. I leave the pickup on a table so that the wax will flow over the wires and after cooling it will protect the wires a bit.
  1. Soldering 42 AWG plain enamel wire to the hookup wire
    By Mack Guitarworks in forum Pickup Makers
    Last Post: 03-04-2016, 02:10 AM
  2. De-Soldering Lead-Free Solder PCB joints
    By nevetslab in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-29-2014, 08:41 AM
  3. Soldering PCB - JCA50H
    By GRIMESPACE in forum Mods & Tweaks
    Last Post: 08-03-2012, 05:22 PM
  4. what temp for soldering PCB connections?
    By Groover in forum Guitar Amps
    Last Post: 05-21-2010, 04:26 PM
  5. Connecting Magnet Wire and Lead Wire
    By kevinT in forum Pickup Makers
    Last Post: 04-29-2008, 06:21 AM
