Originally posted by mort
View Post
So I have been given free reign to gut a Blues Jr and do whatever I want with it
For reference, this is the best layout I found for the widely-shared one-tube reverb circuit.
I wish I could remember who made the layout so I could give them proper credit and thanks, but I can't find the bookmark I had for the original thread. It is designed to fit on a "daughter-card" that is easy to splice into any amp.
Anyway, I followed this exact layout for the reverb upgrade for my customer, and he loved/loves it. Very warm and fat (as opposed to my "cold/dry room" one-tube 6BM8 reverb driver design based on Eric Barbour's example of a 6BM8 reverb recovery).
Originally posted by mort View PostI see the -20db loss with controls at 5, but I don't see the "x10" (?). Does this look like a healthy configuration?
I see that the mid notch of your tone control has shifted down to 100Hz. Is that OK? It's usually between 500Hz and 1kHz
So the reverb tank in this thing is 800 ohm input impedance and all the reverb transformers I'm seeing have 8 ohm secondaries. Is there a simple way to manipulate this to make them work together or do I just need to get an 8 ohm tank? Or since I still don't have a reverb transformer, is there one that's 800 ohm secondary?~Semi-No0b Hobbyist~
Originally posted by dchang0 View PostBefore you build the reverb circuit, you could always go with a capacitor-coupled reverb driver. This would save you having to buy a reverb transformer and a new reverb tank as well as save space inside the amp.~Semi-No0b Hobbyist~
I found this one but it uses a different tube type.
Channel Road Amplification: Transformerless Reverb Driver~Semi-No0b Hobbyist~
Here's a pretty good analysis:
Doug Circuits
It shows several examples from real-world amp designs.
IIRC, Ampeg and Marshall had capacitor-coupled reverb drivers (Ampeg Gemini).
I also designed and built a 6BM8 one-tube capacitor-coupled reverb. It's pretty powerful and can overdrive the tank. Here is the thread--look at post 55 for the schematic:
http://music-electronics-forum.com/t22458-2/
You should probably change the 470nF coupling cap to something like a 0.022uF. I kinda overkilled it with the 470nF.Last edited by dchang0; 02-28-2017, 09:43 PM.
Originally posted by mort View PostI'm all ears! Got a link to a drawing?This isn't the future I signed up for.
Originally posted by mort View PostYYou guys think that a single 12ax7 triode will do the work of the whole 6cg7 in this schematic?
NO.
Ampeg is using one triode for a little gain, the second as a power delivery system. Power, you'll need it. Please consider, if not 6CG7, how about a 12AU7? If you simply sub in a 12AX7 here, you may find yourself subbing that 12AX7 a lot, as it will be way overstressed in this application. Yes I know, Mesa Boogie use an AX to drive their reverb, 400V on the plate OW! - good for them - I don't approve, that's my position & I'm gonna stick to it.
FWIW I have a similar project to yours to complete in March. I'm considering using a JJ ECC832, equiv.to 12DW7/7247. Dual triode, usual footprint. You find them used in Ampeg SVT and some other amps. One triode is like a 12AX7, hi gain low power, the other 12AU7 high power low gain. You may find you do not need the extra gain stage as shown in your Ampeg schemo. Instead of a whole extra gain stage, how about a bypass cap across the cathode resistor in the drive amp? That'll give us some cheap gain, almost for free, bypass cap might cost a couple of dimes . I'm planning to use the hi power triode to drive the tank, and hi gain to recover the signal.This isn't the future I signed up for.
Not sure of the 70s, but the Reverberocket 2, GU12, Rocket 2, all used 6U10 triple triodes...
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
