Originally posted by Djizix
View Post
JCM 2000 bias pins maxing at 15mV
Originally posted by Leo_Gnardo View PostSo you don't have another annoying too high / too low test run again, check the bias voltage on pin 5, all output tubes before commencing. I'd recommend, dial the adjustment pots so that you read say -43.0V if you can get there, or as close as you can. Same bias V for each pair of tubes. Warm up your prize, read the bias on the test points, it will start out low then increase as you adjust the bias pots closer to -40V.
Originally posted by Djizix View PostI've tried swapping tubes around and have gotten the same result every time I fire it up. And I'm not 100% how to test the bias voltage on pin 5 either.
I'm asking for readings on ALL the output tube sockets in case say you have the bias voltage at -45V for one pair and -35V for the other pair, that sort of thing would explain why you're getting widely different bias readings from the test points. It would make sense to start with the bias voltage matched and on the high side, that is further away from zero, then adjust to the appropriate level.
I fear that if you cannot make these kind of measurements you're over your head with or without a new board, and perhaps this task is best left to someone with more expertise. Where are you located, perhaps some kindly MEFster is within easy driving distance, you could take it there and get help.This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostI fear that if you cannot make these kind of measurements you're over your head with or without a new board, and perhaps this task is best left to someone with more expertise. Where are you located, perhaps some kindly MEFster is within easy driving distance, you could take it there and get help.
That being said, I suppose when I said I wasn't 100% sure how to do it, I didn't mean I didn't know how to test voltage. That's pretty cut and dry. Perhaps though, I was measuring this bias voltage wrong because my reading wasn't a negative voltage when I attempted this.
So again, if I'm understanding this correctly, I'm to take one tube out at a time, ground to black, and red to the pin 5 insert of the extracted tube? And when and if I test it correctly, the bias pots will adjust this at an appropriate level of negative voltage?
Originally posted by Djizix View PostSo again, if I'm understanding this correctly, I'm to take one tube out at a time, ground to black, and red to the pin 5 insert of the extracted tube? And when and if I test it correctly, the bias pots will adjust this at an appropriate level of negative voltage?
You could do it that way, or if chassis out of box, you could approach pins 5 from the back of the circuit board, with tubes in sockets, no need for removal. Of course being careful as I'm sure you know how, one hand in your pocket so you can't get a shock. Another of this amp's unexpected quirks, the bias trim pots adjust the pair of tubes - and test point - opposite the trim pot location. Another Marshall circuit trick to drive us crazy.
I hope this helps!This isn't the future I signed up for.
Originally posted by Djizix View PostSo I tested the 22k variable resistors on the bias board to the best of my ability. I'm having trouble identifying which is positive and which is negative, but I'm fairly sure I have the neutral nailed down. Either way, I alternated the black lead accordingly and my readings were on one side, fluctuating around 11-22k and the other side was 14 ohms turned counter clockwise, and 25 ohms clockwise. Doesn't seem right, but I don't really know.When the going gets weird... The weird turn pro!
Originally posted by DrGonz78 View PostSomething about this part of your observations here needs more understanding. If one side is 11-22k and the other bias trim pot adjustment is between 14-25ohms then something there needs to be looked at better. I guess this part left me confused a bit as to whether I understood it correctly. Then I read that one pair of tube is pulling a butt load of current and the other is barely pulling any. Of course measure your pin 5 bias supply voltages like Leo mentioned first. Still perhaps there is something off about that that Bias Board adjustment readings.
Also tested pin 5. On the left pair I was able to get my bias voltage at -35v. This is the side that is biasing at 130mV. Yes I know the pins are backwards. The right side pair was at -48v. This side would only bias at 8mV. So I have no idea where tis leads me.
Originally posted by Djizix View PostAlso tested pin 5. On the left pair I was able to get my bias voltage at -35v. This is the side that is biasing at 130mV. Yes I know the pins are backwards. The right side pair was at -48v. This side would only bias at 8mV. So I have no idea where tis leads me.This isn't the future I signed up for.
Here is a schematic of the 'bias' board.
jcm2-64-02.pdf
If you want to test the controls, unhook the connector at the main board.
At the bias board header, measure the resistance from pin 1 to pin 2 & from pin 1 to pin 6.
When you rotate the adjustments, the value should change from zero ohms at one end of the adjustment to 22K at the other.
Both controls should read the same.
Reading across pin 1 and pin 7 should be double the value of each 22K control. (they are in parallel).
The adjustment screw has no affect on this reading.
I will tear her open and test as soon as time allows. In the meantime though, if I do have shot variable resistors, would anyone have any idea where to get a matching set? Id prefer to not have to mod this tiny little chip. Also, does anyone know if a new pcb would come with a new bias chip?
Originally posted by Djizix View PostI will tear her open and test as soon as time allows. In the meantime though, if I do have shot variable resistors, would anyone have any idea where to get a matching set?
I'm sure Digikey, maybe Newark or Allied will also have these or others like them.
http://www.mouser.com/Bourns/Passive...yzbppyZ1z0z54uThis isn't the future I signed up for.
Originally posted by Jazz P Bass View PostHere is a schematic of the 'bias' board.
[ATTACH]42619[/ATTACH]
https://www.amplifiedparts.com/produ...acement-dsl100
That is the source that I know of to replace the main board on the DSL100. Pretty expensive but it does help rebuild your confidence in the reliability of the amp again. Did you every measure bias voltage at pin 5? Also, it is wise to check all the output speaker jacks to see if any are worn out and open. The jacks are supposed to be closed circuit when no plug is inserted. I have one here that one of the 4 ohm jacks tip is open and will not mechanically close any more. That part needs to be investigated either way if you buy a new board or not since your still going to be using the output board in the amp.When the going gets weird... The weird turn pro!
Originally posted by DrGonz78 View Posthttps://www.amplifiedparts.com/produ...acement-dsl100
Otherwise, excellent find DrGonz! And in your neighborhood too. If they're in stock, sure beats sending away to England, in hassle, time waiting for delivery and $$$.
Antique and CE customers take note, same part #. What a coincidence!
It's been said before, so I'll say it again. If this series of JCM2000 amps were cars, Marshall would have to conduct a recall program and fix their problems at no cost to the customer. Add that to your aggravation list folks. Grrrrr......Last edited by Leo_Gnardo; 03-06-2017, 03:49 AM.This isn't the future I signed up for.
Originally posted by Leo_Gnardo View Post??? Closed circuit, as in shorted like Fenders?When the going gets weird... The weird turn pro!
